Old Nov 03, 2009, 09:47 PM
heligrom is offline
Find More Posts by heligrom
Sippin' on Kool Aid
Long Island NY, USA
Joined Dec 2005
Cellfoam 88 vs Depron for building
Hey guys, quick question about building materials:
I'm placing an order with tower and noticed they carry Midwest products cellfoam in 3mm thickness. How does this stuff compare to depron?
If i recall correctly, i heard its similar. I'm wanting to do a lot of scratch building F3P for this winter season and i figure i could just throw it on with my order from tower.
heligrom is offline Find More Posts by heligrom
Old Nov 03, 2009, 09:57 PM
$$J3ft$$ is offline
Find More Posts by $$J3ft$$
GO FAST OR GO HOME!!!!!!!
Joined May 2007
same stuff
$$J3ft$$ is offline Find More Posts by $$J3ft$$
Old Nov 04, 2009, 09:40 AM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
If it's the same stuff that Cellfoam was a coupel years ago, it is most definitely NOT the same stuff. The Cellfoam is much more brittle. If you bend it, it hits a certain point and then breaks with a very definitive snap. I don't know about weight, but it's kind of obnoxious to work with.
hpapilot is offline Find More Posts by hpapilot
Old Nov 08, 2009, 08:27 AM
F7X is offline
F7X
Find More Posts by F7X
F7X
Faster!
F7X's Avatar
United States, NV, Sparks
I like CellFoam. I used it to build several aircraft, including a little EDF with a curved intake. With a little heat from a heat gun, I was able to mold and form it into just about any shape. The duct on this little EDF-40 powered plane is made of a singe piece of 3mm. If your going to place an order with Tower anyway, get some and give it a try!
-Joshua
F7X is offline Find More Posts by F7X
Old Nov 11, 2009, 03:50 PM
skootertrash74 is offline
Find More Posts by skootertrash74
United States, IN, Indianapolis
Joined Nov 2008
cellfoam is awesome stuff! it's all i use and my lhs stocks it.
skootertrash74 is offline Find More Posts by skootertrash74
Old Nov 11, 2009, 04:38 PM
CAFplanekid is offline
Find More Posts by CAFplanekid
De-Brushed user
Midland, Tx / W. Lafayette, Ind.
Joined Dec 2002
I have not used CellFoam 88, but I have seen it in Michaels and Hobby Lobby craft stores, if anybody is looking to try some.
Jonathan
CAFplanekid is offline Find More Posts by CAFplanekid
Old Nov 21, 2009, 03:42 AM
Thomas Manson is offline
Find More Posts by Thomas Manson
Tee Sqaured
Thomas Manson's Avatar
Langley, B.C, Canada
Joined Jun 2001
It is very similar to depron, but it is denser. I built a Index 2.2 from the plans and once cut out, my pile of foam parts was about 15 grams heavier than the exact same parts cut from depron.
My AUW was 140 grams, and would have been 125 had I used depron. For larger designs it's less of a problem, but for F3P designs it's a touch too heavy.
Thomas Manson is offline Find More Posts by Thomas Manson
Old Nov 28, 2009, 04:32 PM
maukabud is offline
Find More Posts by maukabud
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
It's NOT the same stuff. I use both and have found that the cellpro has kind of an outer "skin" finish on both sides. It bends before it breaks (leaves a crease in the skin), whereas Depron just breaks. I feel that 3mm Depron is just a bit stiffer, 3mm Cellpro is a bit denser. For 3mm indoor a/c, either works great. For 6mm outdoor, I would choose Depron over Cellpro.
maukabud is offline Find More Posts by maukabud
Discussion FoamCore VS Depron and CellFoam gittarpikk Foamies (Scratchbuilt) 3 Jul 03, 2009 10:07 AM
Discussion FoamCore VS Depron and CellFoam gittarpikk Foamies (Scratchbuilt) 0 Jul 02, 2009 08:46 AM
Discussion Cellfoam 88 vs. Depron for DLG Elmog Hand Launch 5 Dec 10, 2007 11:25 AM
Discussion Cellfoam 88 vs. Depron Elmog Foamies (Scratchbuilt) 9 Dec 09, 2007 11:49 PM
Cellfoam 88 Pa28 The Builders Workshop 9 Feb 10, 2005 10:28 PM
