Old Jan 02, 2013, 10:53 PM
Joined Oct 2008
Striker F-27Q with GOPRO3 flight issues
I have a GOPRO3 mounted on a striker F-27Q and am having some problems.
I was wondering who else has been doing this with success? How did you set the camera up?
I have the camera right above the recommended CG. First flight went fine. Second flight was a total failure. No change made to the striker at all. Just pulled the battery and charged it between fights. During the 2nd flight I could not get the plane to level out. It acted very tail heavy. Below are links to the flights. Any thoughts would be very helpful.
Here is a pic of the setup. I secure the camera with Zip Ties
http://www.rcgroups.com/forums/showa...=5417247&stc=1
First Flight:
First Flight of the Striker with the GOPRO3 (3 min 58 sec)
Second Flight
Failed Striker Flight (0 min 16 sec)
heiifyre is offline Find More Posts by heiifyre
Old Jan 03, 2013, 11:46 AM
Fremont, CA
United States, CA, Fremont
Joined Jan 2009
The camera, being quite high above the fuse, might be the cause of pulling the nose up especially at higher speeds.
djacob7 is offline Find More Posts by djacob7
Old Jan 10, 2013, 02:13 AM
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
yes, its 100% because the camera is up on the tail.
The CG is not everything. The wind force on the camera according to your mounting picture is *huge*. It will fly, but it wont fly well.
you will need to put it at the front and deal with the battery so that the cg is mostly ok. make sure it's more or less aerodynamic ;-)
here's an example: http://cdn7.modelairplanenews.com/wp...419.jpg?97b01b
CrashMeUp is offline Find More Posts by CrashMeUp
Old Jan 10, 2013, 09:25 AM
Joined Oct 2008
Thanks for the info. I will give that a try.
Discussion Help with a F-27Q Micro Stryker from Parkzone AtGame7 Beginner Training Area (Aircraft-Electric) 12 Feb 22, 2013 08:18 PM
Cool Stryker F-27Q first 2 flights FlybyPDX Electric Plane Talk 0 Apr 07, 2012 03:51 PM
Cool First two flights on Stryker F-27Q FlybyPDX Flying Wings 0 Apr 07, 2012 06:36 AM
Discussion Noob with motor issue - Parkzone Stryker 27Q FailureToFly Beginner Training Area (Aircraft-Electric) 13 Mar 25, 2012 10:14 PM
For Sale Parkzone Micro F 27Q striker guts combo Racerx4 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 12 Jan 23, 2012 10:08 PM
