Closed Thread
Old Mar 14, 2014, 07:40 AM
Reneke's Avatar
The Netherlands, LI, Urmond
Joined Dec 2013
Originally Posted by uptime4downtime View Post
Good job. It looks to be doing the trick.
I don't like the performance of the A2200. Looking for an A640 now, or simular.
--> any updated suggestions for 2014 regarding cheap (ebay) models to use for AP?
Reneke is offline Find More Posts by Reneke
Old Mar 14, 2014, 06:49 PM
3d Kiwi
uptime4downtime's Avatar
New Zealand
Joined Dec 2007
I can't recommend anything cheap, as the Canon line all kind of look the same at the cheap end, and some of the newer, cheap models wont have CHDK yet. So it really takes getting into larger sensor models which do cost more. You might find a good deal on the Sony RX100, but you will need to use a servo. Otherwise the NEX, which your Scarab will probably lift just fine. You should find a good deal on a Nex 5 or so, and get the cheap pancake lens to save weight. Would be better for sure than the A2200 and you can get trigger systems for it also.
uptime4downtime is offline Find More Posts by uptime4downtime
Old Mar 15, 2014, 03:40 AM
Reneke's Avatar
Joined Dec 2013
... You should find a good deal on a Nex 5 or so, and get the cheap pancake lens to save weight. Would be better for sure than the A2200 and you can get trigger systems for it also.
Thank you for the info.
Yes Nex 5 with decent brushless gimbal is my end target. But first, get more experienced in flying (total rookie) and taking real estate pictures with this setup.
I found a canon A640 in the meanwhile; it is on it's way.
I am a bit worried how I am gonna get the right composition. I'm gonna go for the 'statistic approach': take a zillion pictures and hope that some percentage is OK. Is there an alternative?
Old Mar 15, 2014, 08:58 PM
3d Kiwi
New Zealand
Joined Dec 2007
Statistic approach is the best. I assume you have video downlink? That and zillions of images is the best bet. Once you have things dialed in, you can reduce the image count a little. The 640 will be very good I'd say!
Old Mar 21, 2014, 10:16 AM
Surrey UK
Joined Nov 2005
Still doing tests with the Canon S95
Settings are
ISO 125
1/1000th at F5.6
IS switched off
Cloudy day
Geoff Chapman is offline Find More Posts by Geoff Chapman
Old Mar 21, 2014, 11:24 AM
United States, WI, Madison
Joined Dec 2011
Can you set the next to take pix every second like the GoPro?
pixeltim is offline Find More Posts by pixeltim
Old Mar 21, 2014, 05:40 PM
3d Kiwi
New Zealand
Joined Dec 2007
Yes, with CHDK, not a problem. Ultraintervalometer is the best script for that. Load up the script in CHDK on the camera, and good to go.
Nice going Geoff. I can get keepers on the S90 series if I work hard at it. But hard mounted I still have issues.
Old Mar 21, 2014, 05:57 PM
Reneke's Avatar
Joined Dec 2013
Yes, the A640 is better than the A2200. About 80..90% sharp results @1/320 - 400 ISO. Next experiment: slower shutter speed and lower ISO
Old Aug 19, 2014, 01:24 PM
Reneke's Avatar
Joined Dec 2013
Looks like this thread is dead. Any follow ups? New threads?
Old Dec 12, 2014, 04:19 PM
3d Kiwi
New Zealand
Joined Dec 2007
Sorry, late reply. Yes, with the advent of multis like the Phantom, and a whole new range of camera options, technology has moved things on. If you are still using these cameras listed in the thread, the information still applies, but with micro cameras (eg Inspire) shooting RAW and increasing in quality, it has changed things.
Closed Thread
Discussion Alert: Be careful with finshlinerc, or Larry Tucker of Santee, California. flyer368 Trader Talk 45 Sep 11, 2011 12:26 PM
Discussion Liberals: Be careful what you wish for.. Dave Campbell Life, The Universe, and Politics 77 Dec 19, 2007 03:59 PM
Be careful what you wish for. Dewey12 Thermal 1 Feb 09, 2005 09:26 AM
Puerto Rico - Be Careful What You Wish For! Big Foot 48 Life, The Universe, and Politics 4 May 13, 2003 07:57 PM
