Old Oct 20, 2010, 08:52 PM
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
Making small props for micros
Making small props for micros & pico .
I have been looking all over here and whole web on making props .
everything form large PVC pipe blade for windmills down to bent strip of tin on old free flight.
i know laminated wood is nice for scale and much exists .
but what would be good or I and a few others are after is reliable props and hub tricks . for 4mm motor range .. like a pico Z tail rotor up to mini storm launcher style .
i tested cutting a straw as if it was a PVC pipe style an it works but you have to laminate the blades for them to have any strength.
my next tests will be printing blade laminations out on paper and laminating them with WBPU , or epoxy .
all ideas welcome for pico to UM size .
Prime_8 is offline Find More Posts by Prime_8
Old Oct 20, 2010, 09:29 PM
"Unnecessary Necessity"
coriolan's Avatar
Canada, QC, Quebec City
Joined Sep 2006
Here are a few pictures of how to make props and description from MPS(in French):
http://www.microplanesolution.com/mps_000003.htm
Homefly has the didel hubs prop connector, Didel PC03-10,prop connector, Didel PC02-7(they are discontinued by Didel so better grab what's left!).
http://www.homefly.com/products.asp?id=10&pg=2
Have a look at several of these for ideas:
http://www.aeronutz.flyer.co.uk/
coriolan is online now Find More Posts by coriolan
Old Oct 20, 2010, 10:30 PM
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
lol wow great links ,
i can read french . a bit .. lol
great ideas in there . easpecialy last link .
Old Oct 20, 2010, 10:34 PM
Nelo Tadeo's Avatar
México D.F.
Joined Aug 2006
here there are... but in spanish...
http://www.rcgroups.com/forums/showthread.php?t=918011
...............☼.......Leo
Nelo Tadeo is offline Find More Posts by Nelo Tadeo
Old Oct 20, 2010, 10:44 PM
coriolan's Avatar
Joined Sep 2006
Before molding the carbon fiber on the bottle just drink the wine and it will translate easily
Old Oct 20, 2010, 11:33 PM
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
i was all about the wine .
i also like teh yogurt cups idea .
LOL
i my try to use the bottom of a soda can in a bit diff way .. using it as ajustable link between blade and hub for testing pitch .
also some materials are hard to come by without special orders. LOL
but great stuff so far.
Old Oct 20, 2010, 11:46 PM
Post Digger
Baratacus's Avatar
San Diego, CA
Joined Oct 2005
I used a styrofoam plate, cut the paddles out of the slightly bowled edge of the plate for some concave. Used .5mm CF rod and pushed it through a pinhole in a piece of wire insulation. glued the paddles to the rod pressed the wire insulation over the prop shaft. I've done this with a two and three blade configuration and they've been the lightest props I've built. with .5mm rod I went all the way up to a 2 inch diameter and it required gearing on a 4mm pager. On the three blade prop it was necessary to use a bit of CA glue on the hub to keep the blades from twisting and changing pitch.
I've also emulated the picoo-z style tail rotor using the same outline but scaling it up , then cutting the blade from a yogurt cup and twisting it to the propper pitch with a little heat The're a little heavier than the foam blades but they can be run direct drive at much higher rpm. Anything bigger than the picoo-z size blade and you need to go up to a larger motor or reduce the pitch.
Baratacus is offline Find More Posts by Baratacus
Old Oct 21, 2010, 12:08 AM
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
i have about 20 aor so kits like this i did up for slider.
but just loose. so i should be ok for a few diff prop sizes ...
but i only have afew pico z style blades left . LOL
Old Oct 21, 2010, 02:53 AM
cabman1969's Avatar
Melbourne, Australia
Joined May 2008
Hey prime, somewhere I ran across a thread where someone was making props in a homemade vacuum former. Its a really good idea as you could use another prop as a mold to make a much lighter version. Granted theres a little trimming involved but think of the possibilities. Once you have the mold you want your in business. You could use slightly thicker or thinner material for weight and stiffness applications, anyway ill see if I can find the link..
cabman1969 is offline Find More Posts by cabman1969
Old Oct 21, 2010, 03:22 AM
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
i saw one here too .
it was pretty cool but requires have the target props . so that's ok for my pico Z and air hogs blades .. and such i have .
could make em out of paper and PU.
then make molds of them . or carve a blade in hard wood , make a mold of it , then make mold(s) using multiples of that blade . LOL
well i still have to get home and try a few ideas out . LOL
Old Oct 21, 2010, 10:57 AM
Storm Runner guy
Slider2732's Avatar
USA, OK, Muskogee
Joined Nov 2008
Great thread Prime_8
Yep, i'm right at that point too, where for some projects, even the little heli rotors are heavy !
The paddle type seem the way and that method there Baratacus is very clear, thanks.
Slider2732 is offline Find More Posts by Slider2732
Old Oct 21, 2010, 12:59 PM
Post Digger
Baratacus's Avatar
San Diego, CA
Joined Oct 2005
on the two blade paddles if they share the same rod you're stuck with the pitch that you glue the paddles at. Upside is that they're cheap and easy to make. You can build 20 props with various diameters and pitch in about 10 minutes. with the three blade each blade had it's individual paddle so they could be twisted individually. This means balancing the pitch to be equal on all the paddles, but it also means you can adjust the pitch of the prop before you set it in the hub with cement. I liked the paddles on my scale aircraft that i wanted the prop wash to clear the fuse. I could put small paddles towards the end of the CF rod and throw a larger diameter prop but without the resistance of a full blade prop of the same diameter.
Old Oct 21, 2010, 01:17 PM
Filin Sergey
kulibin2's Avatar
Ukraine-Mariupol micro-plane.com
Joined Mar 2009
My prop http://micro-plane.com/index.php?opt...mid=13&lang=en
kulibin2 is offline Find More Posts by kulibin2
Old Oct 21, 2010, 01:50 PM
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Don't forget that Google (search) has its Language Tools to translate from just about any language on earth to any other language.
Also, if you use Google Chrome as your browser, it will automatically ask you if you want a foreign website to be translated into English (or whatever language you selected as default when you installed it).
356Jim is online now Find More Posts by 356Jim
Old Oct 21, 2010, 04:55 PM
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
Originally Posted by kulibin2 View Post
wow steps 12 & 13 could work for many materials.
very good way for light and strong blade forming .
and one can ajust pitch of prop by bore # on bit . LOL wicked ..
now i need magnet wire .. LOL actualy have soft baling wire should work teh same.
Discussion Small Folding Props Xptical Electric Sailplanes 6 Sep 22, 2010 12:11 PM
Discussion small props Homeport Micro and Sub-Micro Boats 5 Sep 20, 2010 02:45 PM
Discussion Thinking of making a small RC windtunnel for testing the airplanes skilet Parkflyers 1 Dec 09, 2008 06:27 PM
Discussion Small props for small shaft motors. Skonkworkstexas Power Systems 1 Mar 05, 2006 08:14 AM
Photo Etching - a "How To" for PCB boards and making small metal parts. planeman Scratchbuilt Indoor and Micro Models 81 Jan 04, 2006 03:49 PM
