Old Nov 12, 2008, 08:50 AM
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
weather flyable today but a bit breezy...
so out for a quick go with the octagon...
I am still using the little blue motor on this 29 1/2" version and its flying well, no problems but I think the COG wants to be 25% as per the nutball..I am flying with the COG back a bit, and when I put it inverted it climbs by itself and returns to a normal upright flying position..
Normal flying OK... similar to the NB which is expected, but it also seems slightly less stable..this could be because its a fair bit lighter than my big NB..but it rolls faster and loops smaller...so I am not certain...
It was floating well and could be harriered ok in the breeze, but it was also getting knocked about quite a lot..The little blue motor copes well with all general flying but it hasnt enough power for vertical go..
So next I am going to try the heavier/bigger motor plus a bigger battery to get the COG forward a bit more and give it a bit more weight to help in the poor conditions we normally fly in here
this is the little blue motor
http://robotbirds.com/catalog/produc...oducts_id=1787
I will get some video soon if this weather holds good
davereap is offline Find More Posts by davereap
Old Nov 13, 2008, 04:26 AM
davereap's Avatar
Joined Feb 2005
installed a larger motor and esc AUW previously 15.25oz now 17.25oz depending on battery this can be up to 18.5oz.... the more forward COG of 25% is now easily obtainable and is recommended, at least as a starting point....
this is the bigger pink motor..
http://www.overlander.co.uk/product....id=82&pid=2581
Old Nov 13, 2008, 08:33 AM
davereap's Avatar
Joined Feb 2005
I have now flown the more powerfull version and, without doubt it is my best yet...
I think its because it is lighter by 4-5oz than my big NB and so it has a better power:weight ratio
heres the video
The octagon or 8ball - a Nutball version KFm2 (3 min 34 sec)
Old Nov 14, 2008, 04:46 PM
Onward through the fog.
Cybernaught's Avatar
Bohol Philippines
Joined Aug 2008
Nice vid Dave,
You make it look so easy.
Well the head gasket on the car blew on the way back from Tagbilaran so the car is in the shop and we're house bound for a bit. I'm also caught up in the middle of some honey-do's. The 8-ball, Nutball variant is ready to go but not sure when I can get out to the school. Wanted to go this weekend. Maybe we can take a tricycle. I have a carpenter here working on my boat at the moment too. Just a busy time and weather isn't cooperating either.
Same problem you had but at least here it's warm rain.
Steve.
Cybernaught is offline Find More Posts by Cybernaught
Old Nov 14, 2008, 04:49 PM
davereap's Avatar
Joined Feb 2005
Glad you liked the video..this sized rudder verson has turned out to be a great flyer..I think even better than my big nutball...I think the better power:weight ratio has everything to do with it
Old Nov 14, 2008, 04:55 PM
davereap's Avatar
Joined Feb 2005
CONSTRUCTION NOTES
.... for the 6mm depron version
The build is identical for the normal round nutball shape
1.... draw up the octagon shape, using a series of parallel lines ...note a 12" set of lines will give you a 29.5" flat octagon and is a good size..
Cut one complete octagon for the main skin, and one half octagon for the top skin..Or cut one circle and one half circle
Old Nov 14, 2008, 05:01 PM
davereap's Avatar
Joined Feb 2005
2.... cut a balsa spar 1/2 x 1/4...this is to be glued at the 50% step position
cut a depron spar ...(width not critical)...1.5" wide this goes between the skins at about the 30% position
each spar has three parts as seen in pic 2 ...the end sections are tapered from about half their length from 1/4 down to 0 thickness..
pic 3 shows the tips cut and glued and the spars also glued to the bottom skin
each tip is raised by 3" the joints were chamfered to about the correct angle, they were then glued with uhu-por ,, a cool melt glue gun was used running along the joints top and bottom to fill any gaps and strengthen the joint
the cool melt was also used to strengthen the spar joins.
Old Nov 14, 2008, 05:22 PM
davereap's Avatar
Joined Feb 2005
the last main part..the top skin can now be fitted..
first the centre section ...then each of the tips... the tips will need some triming to get the edges champhered and because theres a slight curve the edges will need to be shaped a little bit to acheive a good fit..
fit dry first
Then apply uhu-por in about a 1.25" width arround the edges where the two skins will be joined ...and also use the uhu on the top of the balsa and depron spars
important note always laminate putting the rear edge down first onto the balsa spar..work forward to the depron spar then to the leading edges..
also work from the center first and go outwards with your pressure
Do your laminating on a flat surface...I use a glass topped table ..this is where you get a flat wing..or build in warps if you are not carefull
Another run arround with the cool melt gun is now the job..fill any gaps and put a thin layer along all seams
Old Nov 14, 2008, 05:33 PM
davereap's Avatar
Joined Feb 2005
Engine mount
cut a slot through both layers to accept your mount, stick or tube type, glue the mount in using the cool melt gun..filling the slot....remember to cut for any side thrust and, when you glue, angle the mount down for the down thrust..
To reinforce the mount cut a 3" width 6mm depron for below, and a 3" width 6mm depron for the top..the depron goes from the leading edge back to the 50% step
Laminate these on using the uhu-por
Old Nov 14, 2008, 05:46 PM
davereap's Avatar
Joined Feb 2005
Tail and Rudder
note the tail fin takes a lot of stress...so
Fix the tail fin in place with a couple of small side supports using epoxy..
Also fit a length of 2mm CF rod down its leading edge.. this goes through the wing and into a hard balsa underspline or block, which is also epoxied in place..My 1/2 x1/4 hard underspline ran from the trailing edge forward to the 50% step location
The CF rod is taped to the fin using 2" colored packing tape..
Reinforce, stiffen and strengthen the fin with a complete layer of the colored packing tape...similarly cover the rudder and use the tape as a hinge.
Old Nov 14, 2008, 05:49 PM
davereap's Avatar
Joined Feb 2005
Taping it up
Elevator and Rudder
cover both sides with packing tape..this realy stiffens it up..put more tape top and bottom along the trailing edge of the wing... use more tape to hinge the elevator
Tape decor and reinforcing
Use the 2" wide tape..(zagi type of idea...available from staples in the UK)
tape top and botom of the leading edges, then all seam joints, even though they were glued..then another strip on top of, and below, the KF strip..It realy does add a lot of strength for only a bit of weight
You can cover the whole airframe if you like but it will add about 1.5-2oz .
Old Nov 14, 2008, 06:01 PM
davereap's Avatar
Joined Feb 2005
Radio fixing
The servos are surface mounted with double sided sticky tape then glued with the cool melt adhesive... they wont come off without taking the depron as well..
The remainder of the gear is fixed on using velcro strips and tiedowns as seen in the last pic above ..
.sorry about its patchy nature but it was made by chopping up the first prop in slot version which had turned out no good. you can see the repairs where I removed the servos and filled in the prop slot holes etc
motor see post 77 prop 9x5gws 11.1v lipo
video
Old Nov 14, 2008, 06:16 PM
davereap's Avatar
Joined Feb 2005
Wheels
two strips of velcro on the 2"wide depron lower reinforcing strip hold a removable trike UC in place
build here... http://www.rcgroups.com/forums/showp...16&postcount=2
Alternativly you can use the two wheeled version if you like...
But for the two wheeled version you will need to fit a spline fuz underneath the main wing
my choice is for the trike version..
Old Nov 17, 2008, 12:42 PM
gladwin,mi,usa
Joined Sep 2000
I'm about to try building this plane and was wondering if the kf wing design was just used on the center section and not the dihedral wing tips, would that signifantly change the flight characteristics? It would seem to save a fair bit of weight (foam, glue, and tape) and also be a lot easier to build since you wouldn't have to fit the tips.Also, I'm not real familiar with the kf wing design, but I did read where the thickness should be about 7%-9% of the chord. Do they figure that on the total chord(29" in this case) or just back to the step(14.5" in this case). Based on this design there is a 3/4" thickness on the wing at the step. This may sound basic but I'm a little confused. I have built and flown a 20" Dia NB but I wanted something bigger and heavier to handle the wind. Thanks for the help.
bluemax is offline Find More Posts by bluemax
Old Nov 18, 2008, 10:56 AM
davereap's Avatar
Joined Feb 2005
I havnt tried just using the KF on just the centre section, but used on the whole wing it does add a lot of stiffness...Try it, you can always add the tip sections later on..
For the step depth, I have been using a 1/4 thick balsa spar then glueing the depron on top..so the total step depth is about 12mm...(if you build with 6mm depron or 9mm if youve used a 3mm top skin)..this is the same all across the centre section ..from there the balsa gets tapered down to zero stopping 1 1/4" in from the edges so you can glue the layers together...personally I would use all 6mm depron of FFfoam whatever..the thinner depron does not save a significant ammount of weight..
Not accurate to the reccomendations on the KF thread, but it works, and you can see from the video that it will glide quite well..
In my different trials using the KF step, I have gone down as low as a 4% step depth, and the thing (the KF step) still does good...so I dont worry too much, I just dont get the tips with too thick a section...10% of the chord max..I always keep the step at a constant depth, even on tapered wings...so the ratio of step depth to chord can be half as much at the centre compared to the tips..
I would recommend going onto the tips as well, but this is for strength more than for performance..with the step you can handle the plane by the tips...without? you will just have to try....even a NutBall with no step goes well..
dont forget the tape reinforcing ...this again makes the whole thing a lot stronger for only a bit of extra weight....
for comparisons..
29.5" octagon video....
flying at 17.5oz
32" nutball video....
Nutball RC 32" KFm2 (6 min 2 sec)
loads of tape decor .. flying at 22oz .... 4ozsqft
Discussion Should i build an 8 cell or 10 cell pack for my Eco8? BowerR64 Electric Heli Talk 1 Apr 10, 2008 01:21 AM
Discussion Scratch Build Foamy for a Beginner Peter Walker Foamies (Scratchbuilt) 3 Feb 08, 2008 07:29 AM
Anybody have a quick build design for coroplast? Javias Electric Plane Talk 8 Jul 13, 2004 10:41 PM
BL Motor for an 8 oz. Hellcat??? mars Power Systems 19 Jan 20, 2003 01:59 PM
Will this cheap and quick-build foamy V fly? Biblet Foamies (Kits) 6 Jul 05, 2002 08:45 PM
