Old Oct 22, 2013, 10:49 PM
Austin, Texas
Joined Jun 2001
Seagull YAK 54 ARF 90 Conversion
Any suggestions on a power plant for this guy?
http://www.amainhobbies.com/product_...FUkS7AodUSMAQA
JStory is offline Find More Posts by JStory
Old Oct 23, 2013, 06:48 AM
Oakland township, Michigan
Joined Jun 2005
Hi -
We have two of these at our club and they are a little heavy for their size. In one instance, the plane is powered by a glow engine (no sure the size) and the other by a small gas engine, either a DLE 20 or a 15 cc Evolution. The later one turned out to be quite heavy and not a very good flyer. If you have not purchased the plane yet, there might be more suitable alternatives out there.
If you have, I think that the conversion would be doable with an E-Flite power 60 and a 6S battery. Not sure on the prop, but something in the 16x10 to 17x10 range should work. For a little more power, an E-Flite power 90 would also work although you may have to go to a higher voltage battery (maybe 8S).
Also, the plane require two separate elevator servos. In order to save a little weight, you could switch those for mini's since they are moving relatively small surfaces. You can also opt to use a ligthweight spinner and lighter wheels in order to save a little more weight.
Good luck,
Teo
viva_peru is offline Find More Posts by viva_peru
Old Oct 23, 2013, 02:48 PM
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
I'd likely run a Scorpion 4020-14 with a 14/8 or 15/8 apce prop on 6S/4000/30c or so. This motor will run at 1400-1500watts all day with bursts to 2000w for 10sec.
Another choice might be at HK, the Sk3 series 5055-420 with 15/8-10 on 6s.
fwiw Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Sold Seagull Dewoitine, Giles G-202,Seagull Yak 54 .90 size cowls MIKEYOUR Aircraft - General - Miscellaneous (FS/W) 0 Sep 20, 2013 09:59 PM
For Sale Seagull yak 54 .90, dle 20, for sale LPU seattle flameoutgarrett Aircraft - Fuel - Airplanes (FS/W) 8 Apr 21, 2013 01:46 PM
Sold Yak 54 .90 By Seagull jhaymes2006 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 02, 2013 02:03 PM
Discussion spe 26cc en YAK 54 90 ARF SEAGULL??? es posible? blaster32 Mexico 12 Nov 21, 2010 12:25 PM
Sold Seagull Yak 54 90 Size ARF SoCal 100.00 flynnaire Aircraft - Fuel - Airplanes (FS/W) 4 Sep 05, 2009 05:12 PM
