Old Sep 10, 2013, 03:51 PM
rcplanes1234's Avatar
United States, IA, West Des Moines
Joined Jan 2010
Best Park Range Setup
What is the best setup/equipment for a park flyer fpv setup? I am wanting to go no more then 1 mile, 2 miles at the max. Let me know everyone's thoughts!
rcplanes1234 is offline Find More Posts by rcplanes1234
Old Sep 10, 2013, 07:16 PM
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
2 x 5.8g SPW antennas on a set of Foxtech AIO goggles will do that easily.
Teamsherman is offline Find More Posts by Teamsherman
Old Sep 10, 2013, 07:56 PM
1fullbird's Avatar
United States, NE, Omaha
Joined Nov 2011
By your question I will take a guess you are wanting to try FPV for the first time. Research the beginner threads for basic knowledge as there are no magic pills or shortcuts. Questions on a whole slew of topics are asked and answered for newbies. Now having said that:
Park flyers tend to be no more than a 1/2 mile as that is beyond LOS. At those distances a simple 200 Mw TX/Rx 5.8 gHz video with a set of IBCrazy Clover leaf and Skew Planner antennas will fit the bill. If you are using 2.4 ghz for AC control you should still be good. Remember the goal is also to get your aircraft back, time-after-time. 5.8 is a LOS signal as it's blocked by trees, leaves, hills buildings. Things go real bad when you lose your signal. On the viewing end you can start with a monitor that doesn't blue screen (blue screen of death). your ground station can be powered by LiPOs. There is a ton more I could go into but the threads are valuable source of information.
1fullbird is offline Find More Posts by 1fullbird
Old Sep 11, 2013, 03:05 PM
Blacked out 350z - Texas
Wrice4's Avatar
Joined Nov 2012
Agree.....read the stickies. Thats why they are there. Not trying to be rude, but they will probably answer all of your questions as well as teach you what you need to know next.
Wrice4 is offline Find More Posts by Wrice4
Discussion Best park flyer for wind? Wasame3 Parkflyers 43 Mar 05, 2013 09:48 PM
Discussion What would be the best antenna setup for a medium range FPV glider. vulpina FPV Talk 3 Jan 27, 2011 11:54 AM
Discussion Full Range or Park flyer range? flyrcehelis Radios 3 Jul 21, 2009 10:10 PM
Discussion Best 9303 setup for max flaperon range ClayH Hand Launch 7 Oct 10, 2008 12:51 AM
