Old Dec 13, 2012, 12:21 AM
Calone
Mississauga
Joined Feb 2009
Question
FPV with one camera and two transmitters
Hi all,
I'm doing fpv for a while and I have two Tx/Rx Video systems: 5.8GHz/200mW and 900MHz/800mW.
I found somewhere (HK I think) a diversity receiver which can work with two different Rx's frequencies.
Before buying that diversity Rx, I'm curiuous if I cand use same camera with two different Tx's. I mean... if I can wire black&yellow in parallel to two transmiters.
Thank you,
Calone
calone76 is offline Find More Posts by calone76
Old Dec 15, 2012, 11:25 PM
Artful Owl's Avatar
New Zealand, Canterbury, Christchurch
Joined Dec 2011
why not just use the 900mhz it should give you the best performance? keep it simple?
Artful Owl is offline Find More Posts by Artful Owl
Old Dec 16, 2012, 05:06 AM
Terry S's Avatar
Bridgwater, UK
Joined May 2003
The load on the camera will be 75r x 2 so the video will be dark unless you use an active splitter.
Terry
Terry S is offline Find More Posts by Terry S
Discussion Flying an RC plane with TWO fpv cameras running at the same time New_Flyer95 FPV Aircraft 1 Jul 13, 2012 05:12 PM
Sold Two cheap radios with receivers .. 6 channel .. one 2.4ghz one 72mhz StampedTees Aircraft - General - Radio Equipment (FS/W) 2 Apr 09, 2012 01:02 PM
Sold Fatshark FPV 5.8Ghz with two pan tilt camera mounts and voltage OSD $315 shipped stretch1100 FPV Equipment (FS/W) 5 Jan 29, 2012 04:01 PM
Discussion Two transmitters, one camera? ziomatrixacs FPV Talk 1 Aug 18, 2010 03:35 AM
Discussion using two Tx's with one Rx for camera control dalbert02 DIY Electronics 0 Jan 01, 2006 08:18 AM
