Old Sep 26, 2015, 03:44 PM
Fidy$Trainer is offline
Find More Posts by Fidy$Trainer
USA, GA, Atlanta
Joined Sep 2008
DX7 Ultra Micro 3ch Setup Help
I just purchased a 3ch Ultra Micro Space Walker. Question how do I set this up on my DX7. This is a 3ch airplane just rudder and elevator. I used a new model and when I bind it the rudder seems to go all the way to the right and doesn't center. I have either a servo issue or setup issue.
Any help would be appreciated.
Fidy$Trainer is offline Find More Posts by Fidy$Trainer
Old Sep 29, 2015, 09:08 AM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
When posting about your dx7, you need to mention if this is the old silver DX7 or the new black DX7. Many times solutions will be different between the two.
First thing to try is resetting the model memory and bind again. If the same thing happens, it's an issue with the plane. If you want to see if it's an easy fix before you return it , first thing to check is to see if the servo is centered, it's possible the control rod is just too long\short...
dacaur is offline Find More Posts by dacaur
Discussion Multiplex Funjet Ultra setup help sp00ky Foamies (Kits) 2 Nov 07, 2014 12:46 AM
Discussion Help with new setup: dx7s/ar8000/nazaMlite xav9237 Multirotor Electronics 0 Jun 17, 2014 11:17 PM
Discussion Need help looking for ultra micro "frame & film" 3D scratchbuilds joker24458 Foamies (Scratchbuilt) 7 Oct 17, 2013 09:11 PM
