Old Dec 19, 2013, 06:34 AM
DjRedFoxx is offline
Find More Posts by DjRedFoxx
Reactor G/P 3D Saito 82a
Joined Jun 2010
EagleTree guardian 2d/3d Problem
Hi Guys,
i just received my new EagleTree guardian 2d/3d Problem for my aeroworks extra 300 QB .60 .90 i set it up inside my model yesterday and all seems to work fine, after i reseted my flight levels and trim as per the manual and it did reset and gave me the indication, i kept it the plane power & Tx power on and turned my head into the maual for 2 min and heard some servo movements i looked bad and my ailerons we out of position banking the plane to the right !! i moved the stick on my Tx and all centered again ? then i observed and saw that the ailerons move a notch banking to the right every 4 to 5 seconds without me commanding so...?
i turned off the heading hold in 2d mod and it stopped doing so ?
in 3D mod it does the same but added the rudder moving to the left with the aileron a notch each every 3 or 4 seconds more gain i add it shorten the time between notches!!!!
Any one knows why is this happening and if there is a solution for that please ??
DjRedFoxx is offline Find More Posts by DjRedFoxx
Help! Guardian 2D/3D servo jitter problem SebbeMalm Eagle Tree Systems 18 Mar 29, 2015 05:07 PM
Discussion Guardian 2D/3D Rudder Problem wedgewalker Eagle Tree Systems 4 Apr 05, 2013 03:05 PM
Discussion Problems with 2D/3D Guardian. Menestrel Eagle Tree Systems 1 Dec 11, 2012 10:27 PM
Discussion Guardian 2d/3d problem dgavalis Eagle Tree Systems 1 Jul 06, 2012 08:37 PM
