Old Jun 18, 2014, 08:04 AM
Dixie Sky Devils AMA# 1015548
tupeloflyer's Avatar
United States, MS, Tupelo
Joined Oct 2012
Parkzone Stenson Reliant BNF
Hello, I have a friend and fellow club member that acquired one of these planes before they were discontinued. It's a BNF so basically all you do is put together and go fly. He's a good nitro pilot, he said he checked it all over good and made sure lipo was fully charged, but every attempt to take off he said soon as he pulls up it snaps to left? I ask if he throttled slow and gradual, and he said he did? I've watched him take off many times and he can fly. I asked if he throttled it up to full on ground and watched surfaces, and he said he did not. what could be going on? could it be a power draw causing a glitch? anyone had a problem with this plane? I've only seen one other, and it flew great!
tupeloflyer is offline Find More Posts by tupeloflyer
Latest blog entry: Sig New ARF 4 Star 64
Old Jun 18, 2014, 09:33 AM
Joined Sep 2010
Welcome to PZ Stinson land - practice, practice practice - seen this one do in many experienced pilots.
bobly is offline Find More Posts by bobly
Old Jun 18, 2014, 10:03 AM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
trim a tiny bit right rudder and see what happens.
cmdl is online now Find More Posts by cmdl
Old Jun 18, 2014, 10:48 AM
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Model must be allowed to get up to flying speed then let it lift off with very little up elevator. Use nudges of right rudder to keep straight during takeoff run. Hold some up elevator to keep tail wheel down during early part of take off run then release to let tail rise. This is a scale model of a 30's luxury plane. Fly it like a scale model, keep climbs and turns gradual until you understand it's flying characteristics. Make sure CG is right. Should be OK with a 2200 mah 3S centered in compartment. Model is easy to fly if you have reasonably good tail-dragger skills. For landings: trim elevator for level flight at 1/2 throttle, reduce throttle to let model touch down on main wheels like a P-51. Don't dive at runway or you will beat up the plastic landing gear parts.
It's a "Stinson Reliant SR-10". There is a very long thread about this model in the Scale ARF forum:
http://www.rcgroups.com/forums/showt...k+Zone+Stinson
E-Challenged is offline Find More Posts by E-Challenged
Old Jun 19, 2014, 09:39 AM
Beaumont tx
Putting in a bit of downthrust (washer under top motor mount screws) will help keep the nose down and smooth out the flight profile.
howell
gwinhh is offline Find More Posts by gwinhh
Old Jun 19, 2014, 10:34 AM
Joined Oct 2000
This model takes off and lands best on smooth dirt or paved field with wheel pants. Taking off from grass is iffy unless grass is short and very smooth like a putting green. Fly in an open area without trees or backstops etc, needs room to maneuver. Fly in calm air, don't fly in high winds or crosswinds.
Sold BNF Parkzone Stinson Reliant SR-10+Lipos Rc_Flyer03 Aircraft - Electric - Airplanes (FS/W) 2 Oct 17, 2013 09:29 AM
Sold Parkzone Stinson Reliant SR-10 BNF Flaps, and new spare wing. Shipped UPS rolis12 Aircraft - Electric - Airplanes (FS/W) 1 Dec 06, 2011 05:02 PM
Sold Parkzone Stinson Reliant SR-10 BNF gdflys Aircraft - Electric - Airplanes (FS/W) 10 Oct 16, 2011 03:36 PM
Article ParkZone Stinson Reliant SR10 BNF Review Bajora Scale ARF/RTF 63 May 23, 2011 01:13 PM
Sold Parkzone Stinson SR-10 Reliant BNF SandHog Aircraft - Electric - Airplanes (FS/W) 8 Dec 30, 2010 06:24 PM
