Old May 03, 2014, 04:18 AM
Finland
Joined Nov 2011
How to reprogram cheapo brushed ESC
Hey there,
I've got this ESC that I've used during the winter on a short-lived car project and now I'd like to put in my boat. The question is how do I reprogram it, or more specifically, must I have the motor connected during the process?
The instruction sheet just says
"1. Switch on the TX power and then the speed controller, slowly advance the throttle, observe the rotation direction of the motor..."
"2. Turn off the speed controller and TX power. You are finished for testing."
So must I apply full throttle while the battery and motor are connected? Seems silly, as it will rev the nuts off the motor.
EDIT: it doesn't have any LEDs or anything.
kormoran is offline Find More Posts by kormoran
Old May 05, 2014, 10:38 AM
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
The esc makes the motor beep (by sending square waves of specific frequencies). If it says turn it on with full throttle, it won't rev up, it will go into program mode.
boaterguy is offline Find More Posts by boaterguy
Old May 05, 2014, 02:16 PM
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
kormoran.
There is no programing as such with those ESC'c.
What the instructions are telling you to do is just check the rotation of your motor & prop.
No, you don't need to go to full throttle.
785boats is offline Find More Posts by 785boats
Old May 05, 2014, 03:22 PM
Finland
Joined Nov 2011
So it appears. Unfortunately the bugger doesn't seem to give full power to the motor. I've tried switching the motor leads around but to no avail - the power seems limited in both reverse and forward drive. Hence the question about reprogramming.
My other ESC, a bit more sophisticated Robbe Rookie 35, gives the boat a normal top speed, but it has other issues (the reverse function is on the blink and sometimes the ESC just ceases to function altogether).
Old May 05, 2014, 06:24 PM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
I didn't realize it was a brushed ESC.
Plug it in while holding full throttle, if you hear a set of beeps release the throttle back to neutral. If you do not, release it after about 3 seconds.
Old May 06, 2014, 02:02 PM
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
kormoran.
Does it give higher revs when you hit reverse with the trigger on your TX ? If so, then you need to reverse the throttle channel on your TX with the selector switch.
These ESC's give 100% forward output but only 50% ( I think) output in reverse.
Changing the direction on the TX should put the 100% in the forward direction.
Note. You may need to swap the motor leads around again to get the right prop rotation .
DO NOT swap the battery leads around. I don't think that they have reverse polarity protection.
Old May 08, 2014, 09:28 AM
Joined May 2014
you are right,you hear a set of beeps release the throttle back to neutral. If you do not, release it after about 3 seconds.
nobikaizhan is offline Find More Posts by nobikaizhan
Discussion Reprogram a brushless ESC to get a brushed ESC with no delays / RC Switch kapteinkuk DIY Electronics 81 Jan 04, 2014 06:29 AM
Question Switch from Lipo to Nimh batt. Do i need to reprogram ESC? nilshv Power Systems 5 Nov 09, 2013 04:00 PM
Found cheapo brushed esc(s) rcbirk21 Aircraft - Electric - Power Systems (FS/W) 3 Nov 07, 2010 06:23 PM
Question Cheapo Brushed ESC on E-Bay vonJaerschky Power Systems 0 Jun 25, 2007 02:46 PM
Found Cheapo brushed ESC for a 380 motor billyzelsnack Aircraft - Electric - Power Systems (FS/W) 2 May 21, 2007 06:07 PM
