Old Oct 08, 2013, 06:11 PM
Norway, Oppland, Jevnaker
Joined Jul 2013
HI
I'm using this servos on the swash servos - works perfect. Had to modify the elevator servo cause it was sticking 2mm out of the body. Works great!
http://www.ebay.com/itm/281080714596...84.m1439.l2649
I also changed the rudder servo but this servo was just buzzing and changed to the
http://www.ebay.com/itm/281092007701...84.m1439.l2649
Now it does not turn - but the tail goes right-left-right-left. Changed the tail gyro sensitivity in all possible values - but it only shifts faster or slower - not steady.. I have a spare original servo so I will try this.
Changed the tail blades to new ones - no difference.
The grub nut tool I already have destroyed - cant get them either more fastened or taken out. I may try to put som purple locktite to the end as You suggested. New tool ordered...
Quite irritating not finding the cause of this. My other X3V fly pefect and I cant figure out where the difference is. But I'll find the solution eventually - You bet!!
OK...
Cheers
Stein
SteinHolstad is offline Find More Posts by SteinHolstad
Old Oct 08, 2013, 06:40 PM
Joined Jul 2013
HI...again
Changed to the original spare tail servo,SCM-9A and the heli acts normal again. Puh... I think I've read something about special issues about the tailservo?
Ok - its half past one o'clock at night here - work tomorrow - up in 6 hours - so I'll better find my bed. I probably find it in my bedrom
Cheers..
Stein Holstad
Norway
Old Oct 08, 2013, 07:37 PM
MightyG
MightyG's Avatar
Joined Mar 2013
Originally Posted by SteinHolstad View Post
HI...again
Cheers..
Stein Holstad
Norway
Yeah, I tried the emax es08md which I think is the metal gear version of the emax es08de that you tried...Couldn't get it to hold properly either, so instead I did a brain transplant from my SCM-9A & a quick hover test went well. I've got the emax servo's installed on my "silver" x3v, but I haven't given it a good test flight yet as it's been to windy!
Good luck!
MG.
MightyG is online now Find More Posts by MightyG
Old Oct 10, 2013, 01:41 AM
when is the wind stopping??
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
Well I still fly mine on stock components and hope to do so for a looooong time hehe but now I am grounded due to a very small thing and really upset that a normal 250 tail rotor blade holder isn't compatible with the x3v tail setup because I would have had that lent to my by one of my flying buddies!! :-/
markkona is online now Find More Posts by markkona
Old Oct 19, 2013, 02:43 AM
Italy, Lazio, Rome
Joined Jun 2012
This is probably compatible and it comes from europe
http://www.ebay.de/itm/WH4-003-Ersat...80649488317%26
http://www.ebay.de/itm/WH4-087-Ersat...item58a07a4023
ercapoccia is online now Find More Posts by ercapoccia
Old Oct 19, 2013, 03:40 AM
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
Originally Posted by ercapoccia View Post
I would have risked buying the first item but it is missing the ball links that are needed to replace the stock tail blade holder and I don't know where I can find those links only!!
Old Oct 19, 2013, 04:03 AM
markkona's Avatar
Malta, Marsaskala
Joined Apr 2011
http://www.rcgroups.com/forums/showthread.php?t=1298516
someone managed to fit the wasp v4 tail assembly on a blade sr!!! I wonder if it can be done on the x3v !
Old Nov 16, 2013, 10:11 AM
Joined Jul 2013
HI
About my tailshaft I now have got the 1.0mm hex and managed to lock the tail metal piece so the tailshaft is level with the hole. What a difference!! No tailspin at all even an full throttle from a low hovering position.
I've written earlier that this grub screw was 0.7mm. That is wrong!! This set from Skyartec works fine: http://www.skyartec.com/ProductShow.asp?ArticleID=1630
I also can recommend theese servos as replacement servos http://www.ebay.com/itm/281080714596...84.m1439.l2649
- works great for swash - but not for rudder/tail servo (after one try only)
Cheers
Stein Holstad
Norway
Old Nov 17, 2013, 12:28 AM
United States, MI, Auburn Hills
Joined Dec 2008
HI
YES THAT IS CORRECT
MUST USE THE SKYARTEC DIGITAL SERVO as it is correctly aligned electronically with the Skyartec Receiver Unit - Analog Servos should not be used on the tail servo connection on the Receiver Unit
Cheers
Stein Holstad
Norway
Max
www.parkrcmodels.com
www.skyartec-usa.com
Parkflying is offline Find More Posts by Parkflying
Site Sponsor
Discussion Hex / Allen Key Differences Witterings 3D Electric Heli Flying 3 May 11, 2013 01:09 PM
Discussion What size generator do I need Rangie5169 Batteries and Chargers 17 Apr 18, 2013 12:38 PM
Discussion Mini cp feathering shaft hex key size? dreamz123 Micro Helis 0 Aug 16, 2012 02:01 PM
Discussion .9mm or .035" hex key needed for 16g hextronic bl**FOUND**I have extras! Murman Foamies (Scratchbuilt) 4 Aug 31, 2008 12:59 AM
What size hex key for Himax gearbox? DrZiplok Power Systems 4 Oct 21, 2004 11:43 AM
