Closed Thread
This thread is privately moderated by Green Fuel Boy, who may elect to delete unwanted replies.
Old Jan 29, 2013, 10:40 PM
Green Fuel Boy
United States, OR, Newberg
Joined Sep 2009
Trader Rating: 24
Sold
RCEXL Tachometer and RCEXL Optical Kill Switches NEW
RCEXL Mini Tachometer or Optical kill switches for sale new in package. $14.25 dollars each let me know which one you want, or two for $27 dollars let me know which two you want. Free shipping USPS CON USA and Canada shipping $3.25 Padded envelope. Paid with Paypal
All items are new in package.
The Tachometer will plug directly into a ignition with Tachometer out put wire. Or can be used with included Y-Cable.
RCEXL Optical Kill Switch NEW Version 2.0 Specs below:
Remotely mounted bright LED ON/OFF indicator light
Fiber Optic Coupled Input/Output
Li-Pol/Li-Ion/A123/Ni-Mh/NiCad Input and compatible
Up to 20 volt 16amp output
100% surface mount technology
Heavy Gauge wire with Universal Connectors
Automatic Shut Down Feature when Transmitter or Receiver is Turned Off
Easy Installation
Light Weight
This unit has no bec
RCEXL Mini Tachometer specs below:
Specification
1.Use PIC16F628a microcontrollers
2.Do not need batteries, Power from the ignition
3.Standard FUTABA plug (Black-Negative Red-Positive and White-Signal
4.Using high-brightness LED digital tube
5. Input voltage range:3.5v-8.4v
6. Current consumption 25mA-60mA
7. Mini tachometer indicates up to 30000 rpm
8. Actual RPM=Display Digital*10
9. Body size:41mmLX17mmWx12mmH
10. Window size:30mmLx15mmH
11. Weight:8.5g(0.30z)
Yes this will work with the RCEXL, DLE, Saito ignition and many others.
Thank you
GFB
Green Fuel Boy is offline Find More Posts by Green Fuel Boy
Closed Thread
Sold Electro Dynamics EDR-107 Fiber Optic Kill Switch ptgarcia Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 04, 2013 05:30 PM
Sold One RCEXL Optical Kill Switch and One RCEXL Tachometer Free Shipping Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 0 Nov 28, 2012 11:53 AM
Sold RCEXL Ignition, Tachometer, Optical kill switch Timing tool Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 0 Nov 02, 2012 06:49 PM
Sold Two RCEXL Optical Kill Switches Free Shipping Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 1 Oct 31, 2012 11:28 AM
Sold RCEXL optical kill switches Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 5 Oct 17, 2012 12:26 PM
