Old Nov 20, 2012, 05:03 AM
Sahrens
United States, HI, Kailua-Kona
Joined Mar 2012
Help!
50cc Yak-54 radio interferance issues
Just looking for any helpful advice or tips. My new (and first ) gasser is a hangar 9 yak-54, 50cc fuji engine electonic ign, all Hi-Tec 625mg servos. I can't seen to get the servo's to stop twitching while the engine is running. I tried twisting the servo leads and used shielded twisted extensions, soldered as many connections as I can to try and fix it. I know it has a resistor type spark plug also.
It starts with the rudder, then every surface twitches, then throttle goes out.
It gets worse and worse as the engine heats up untill the throttle gets twitchy and kills it.
Sahrens is offline Find More Posts by Sahrens
Old Nov 20, 2012, 06:29 AM
Florida
Joined Aug 2004
Need more info. Might be helpful to say what frequency your radio is on.
Are you using separate batteries for the receiver and electronic ignition? Is the radio and servo wiring separated as far as possible from the electronic ignition wiring and spark plug leads? Is the throttle push rod (if that is what you are using) made of non-conductive materiel with no metal-to-metal contacts? Do you have any metal to metal contacts anywhere in the plane that can rub together under vibration? The twisting of wires, addition of chokes etc. will do little or nothing to prevent this type of interference.
Rodney is offline Find More Posts by Rodney
Old Nov 20, 2012, 11:35 PM
Sahrens
Joined Mar 2012
I run 2.4.ghz and yes two batteries. Non conductive throtle rod and I have the wiring separated as much as possible. The worse of it is in the rudder which is a pull/pull setup with metal cables
Old Nov 21, 2012, 06:40 AM
Who Dat!
GeetarJoe's Avatar
United States, LA, New Orleans
Joined Sep 2011
If it gets worse as the engine heats up its probably related to the spark plug wire connection. More than likely it gets loose as it heats up.
GeetarJoe is offline Find More Posts by GeetarJoe
Old Nov 21, 2012, 12:03 PM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
did you make shure the plug cap was fully seated?
whiskykid is offline Find More Posts by whiskykid
Latest blog entry: heli's
Old Nov 21, 2012, 01:37 PM
United States, OR, Canby
Joined Aug 2011
I had the same problem and found others had problems using the HS 645mg. I replaced mine with HS digital servos and they worked fine.
600Bob is offline Find More Posts by 600Bob
Old Nov 21, 2012, 10:34 PM
Sahrens
Joined Mar 2012
The plug wire and plug have a solid connection, I was worried about the servo's/ tx mode
PCM or PPM, it seems to me that I can't run analog servo's on PPM and that using PPM would leave me open to get this type of interferance.
The model flew 3 times with the spektrum AR7000 rx and a DX7 so i'll go back to that setup and see.
Old Nov 22, 2012, 06:39 AM
Florida
Joined Aug 2004
Which is it, 2.4GHz or PCM/PPM, the later are not 2.4GHz?
Old Nov 22, 2012, 11:54 PM
Sahrens
Joined Mar 2012
it'a a2.4ghz radio and it can use either a PCM or a PPM modulation to transmit. I think i'll be safer to use the spektum gear that was installed in the plane already and wait till christmas for my DX8 lol.
Old Nov 23, 2012, 02:57 PM
Keller, TX
Joined Aug 2005
+1
RCFVR is offline Find More Posts by RCFVR
Question AW Yak 54 50cc - PROP TBone08 Giant Scale Airplanes 41 Sep 21, 2012 06:21 PM
For Sale 50cc aero works yak 54 for sale... $550... jimjag Aircraft - Electric - Airplanes (FS/W) 1 Aug 17, 2012 03:10 PM
Sold Aeroworks Rx Ready 50cc Yak 54 W/ DA 50,& Tuned Pipe, Awsome Power! gllucero Aircraft - Fuel - Airplanes (FS/W) 1 May 20, 2012 10:52 PM
Discussion vendo yak 54 hangar 9 50cc. yak 54 quique aircraft 101" Ravelero Mexico 2 Jan 04, 2011 08:14 PM
Sold Lanier Yak 54 50cc size Steve H. Aircraft - Fuel - Airplanes (FS/W) 1 Aug 07, 2006 01:18 AM
