Old Jul 13, 2014, 08:25 AM
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Originally Posted by Spitfire Flyer View Post
$17 for the e-flite spinner seems a little rich. Anyone else try a different 1.75" spinner?
There are some good aluminum backplate -plastic cone spinners - Tower may still carry them
The tiny lightweight all plastic spinners which come on models such as the Artizan are actually quite true running.
richard hanson is offline Find More Posts by richard hanson
Old Jul 17, 2014, 06:41 AM
oldsamer's Avatar
El Paso
Joined Jan 2011
I'm not enthusiastic about spinners in general. They impede cooling air and are in the way when replacing props.
On the 480, after installing bigger motor, ESC and battery I wanted more cooling through the fuse. My latest effort was to block air escaping through the steering gear cutout using a round paper CA hinge and bit of fuel tubing.
That was so successful that the canopy popped off during high speed level flight! So now I rubberband the canopy before flight.
oldsamer is offline Find More Posts by oldsamer
Old Jul 17, 2014, 09:29 AM
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
Mine is fairly pumped up so no spinner and a scoop made for the front inlet. The popping off canopy is a result of the law of unintended consequences
Bluhammer is offline Find More Posts by Bluhammer
Sold 3DHS 41" Blue Edge NIB + Eflite 480 Cabledawg1 Aircraft - Electric - Airplanes (FS/W) 5 Sep 03, 2010 12:58 AM
Question Thoughts on the Ultrafly P51D w/ Retracts lafuerza Electric Warbirds 3 Sep 01, 2010 02:16 PM
Discussion Should I try high Timing on a Eflite 480? Cabledawg1 Power Systems 4 Jul 19, 2010 01:16 PM
Discussion Can't replace shaft on Eflite 480? Lowezz Electric Motor Design and Construction 6 Apr 07, 2009 10:42 AM
Any thoughts on airfoil for 400/480 stuka with scale wing kit basher Power Systems 3 May 19, 2001 11:21 AM
