Nov 25, 2012, 06:17 PM
Seattle
Joined Jan 2003
Hi John,
Yes, life is good at my house here in Seattle. There are many benifits to being single at this age. But, that's a story for another day.
To answer your question. Hyperion motors have a very tuff strong shrink coating on the wires coming out of the motor. It is about 1 inch long. They come straight out the side. If you try and bend them over, there is a LOT of resistance. So........... if the motor is slightly off to one side as mine was, that leaves a gap of about 3/16" , maybe slightly less. When you force the motor in the nose, and bolt it down, the wires are forces to bend over to the side. But, the resistance to that, keeps them hard against the side wall of the nose. The protective coating is long enough to go past the turning drum. To check it, you take a thin piece of wood and push it between the wire and the motor. If you have clearence, your good to go. You only need 1/16" gap. I'll glue the non protected wires against the side wall of the nose for about another inch or so. Use a strong flashlight, look down in there and trun the motor around. If it clears, your good. Hope this helps.
Bob in Seattle
