Old Jul 30, 2012, 01:53 PM
Joined Jul 2012
Can an O.S. 25AX pull Hobbico's Avistar?
It says it has 0.9 horsepower which is very close to the one horse 40LA currently in the plane. And burn 40% less fuel.
Another question: What happened to the 40LA? I can't find any replacements.
theaveng is offline Find More Posts by theaveng
Old Jul 30, 2012, 02:31 PM
RC Addict
rmsingh's Avatar
Ontario, Canada
Joined Mar 2010
I would not take a chance. The Avistar was designed for .40 minimum. Anything less would be risky, personally I would spring for the OS46AX or similar .46 from Evolution, Thunder Tiger etc.
rmsingh is offline Find More Posts by rmsingh
Old Jul 30, 2012, 02:38 PM
Joined Jul 2012
The 25AX in a 40plane is "risky" as in dangerous to me or other spectators? :-o
It's a shame O.S. discontinued those blue LA engines. So what's the difference from FX to AX? The AX appear to spin slower/have less power but I don't know why. Another gentleman said he tried 46AX is an Avistar but didn't like it... too much weight. He went back to the LA.
Old Jul 30, 2012, 05:31 PM
Joined Jun 2009
The LA engines are not discontinued. The color was changed from blue to natural.
ramboy is offline Find More Posts by ramboy
Old Jul 30, 2012, 07:02 PM
Joined Jul 2012
The color wasn't changed. O.S. 40LA engines have always been available in two colors: Blue or natural. I have two of each dating back to 2005. But the blue was discontinued.
Old Jul 30, 2012, 07:54 PM
United States, CO, Arvada
Joined Nov 2010
I agree, 40 sized trainers do way better with a 46 of your choice.
cherokeenut is offline Find More Posts by cherokeenut
Old Jul 30, 2012, 08:04 PM
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
It would very anemic at best or might simply not get off the ground.
I use a 46FX on mine and it goes real good with that.
1320fastback is offline Find More Posts by 1320fastback
Old Jul 31, 2012, 07:56 AM
Fueled by Arabica Beans
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
It will fly, but it will take a long time to get off the ground and it won't do much more than circuits. The Hp might be similar to a .40, but the amount of torque it produces will be much less, resulting in requiring a smaller prop and producing less thrust. To illustrate, the .25AX will be happy on a 9x6 prop, whereas the .40LA will be happy swinging an 11x5 prop.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Jul 31, 2012, 08:00 AM
Joined Oct 2008
The AX are probably evaluated differently than the FX, they are mechanically very similar and should, in the real world perform just as well. In any event, the FX/AX engines certainly have a lot more power than an LA engine.
Old Jul 31, 2012, 07:43 PM
Joined Jul 2012
That clarifies things. Thanks. Would be nice if O.S. published torque ratings too.
Old Jul 31, 2012, 08:18 PM
Joined Oct 2008
Well, they do publish propeller ranges which can give you an idea of what kind of thrust you can expect. Generally planes are designed around a certain sized engine, not based on horsepower, but the minimum thrust that you need and the engines that can swing a prop to give you that thrust. Engines of similar size tend to have similar torque, regardless of power output.
Old Aug 01, 2012, 06:10 AM
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
1) stop looking at horsepower figures. they are meaningless.
2) yes, in fact you can fly most .40 sized trainers on a .10-15 if you know what you are doing. i've done it...
keep in mind you could strap an average sized brick on the wing saddle of a .40 sized trainer with a .40 engine and it would still fly...
a hot .25/28 will fly a .40 sized trainer adequately. provided you realize that you will not be climbing out at 45* 30-35*. the difference is that youll likely settle on a 9*5 prop and trying to turn it about 15k. where the engines this class of plane were originally designed around were turning 10*6's about 12-13k.
youll want more power, and very likely need nose weight, but yes. it will fly.
also, where you get into trouble is crappy ARF trainers like the avistar and alpha are f'ing pigs. kit built trainers that size/type can come out at four 1/2 pounds (without using micro electronics mind you), where its not uncommong for those arf trainers to be at six pounds or more. so you really may want to weigh that airframe considering you can just go buy a used .40-46 on ebay for cheap & clean that up.
Toysrme is offline Find More Posts by Toysrme
Old Aug 01, 2012, 06:27 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Or get one that is already clean from me at a bargin price: http://www.rcgroups.com/forums/showthread.php?t=1688060
u2builder is offline Find More Posts by u2builder
Old Aug 01, 2012, 11:38 AM
Joined Jul 2012
Okay. That means a 25AX which recommends 10x6 prop is about the same torque as the 40LA (also recommends 10x6). Could be an interesting experiment but I think I'll pass.
Old Aug 02, 2012, 08:54 AM
Joined Oct 2008
It's really just engine size that you can compare when it comes to torque. The 25 has a lot less torque than the 40 and it will turn the 10x6 a lot slower than the 40 will (read less thrust), this is a guarantee. Generally, the props that are the biggest recommended will not perform well. I would guess that you would get about 80% of the thrust from a hot 25 versus a 40LA.
Sold hobbico avistar select complete RTF package 48chebbie Aircraft - Fuel - Airplanes (FS/W) 2 Jul 01, 2012 12:30 PM
For Sale hobbico avistar select RTF trainer 48chebbie Aircraft - Fuel - Airplanes (FS/W) 4 Jun 15, 2012 09:16 PM
Sold O.S. 25AX Engine For Sale Dynomike Aircraft - Fuel - Engines and Accessories (FS/W) 5 Oct 21, 2010 05:32 PM
For Sale NIB Hobbico Avistar with O.S. Engine, Hitec Servos, and more BD Flyer Aircraft - Fuel - Airplanes (FS/W) 0 Sep 25, 2009 05:26 PM
Discussion Pulling hair out with Hobbico Avistar ARF flyinmatt Fuel Plane Talk 14 May 29, 2007 08:12 PM
