Old May 04, 2011, 04:03 AM
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
ESM Spitfire 72,5"
We maiden this beauty the other day, very nice.
72,5" Wingspan
actro 60-175 and the Arrowind 5345
3-4 blade 20-22"scale prop
CC ICE 120HV
Jeti MAC BEC 2
ESM retracts
Benedini sound system (RR Merlin)
Jocke is offline Find More Posts by Jocke
Old May 04, 2011, 04:05 AM
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Benedini RRMerlin soundsystem (1 min 3 sec)
Sound system test.
Old May 04, 2011, 04:11 AM
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Pilot and some other scale detales.
Old May 05, 2011, 11:42 AM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
That's a sweet spitty!
How many arming plugs do you have there? Interesting, TW
TripleW is offline Find More Posts by TripleW
Old May 06, 2011, 03:18 AM
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Its arming plugs for the battery, and one MPX arming plug for the Jeti MAX BEC 2.
The battery arming plugs is for safety, and charge without having to remove the wing.
Old May 06, 2011, 09:01 AM
mpope1's Avatar
gilbert,az
Joined Dec 2005
What size prop is that, and who makes it?
mpope1 is offline Find More Posts by mpope1
Old May 06, 2011, 10:37 AM
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
I belive its a beila 22x12" 4 blade. But we usally do our 4 blade props our self, with 2x wood props.
Old Jun 08, 2011, 01:35 AM
kittykatjaz's Avatar
Australia, NSW
Joined Jan 2011
Hi Jocke,
I am in the process of building the same model Spitfire as this with electric power. Would you mind if I asked a couple of questions as it is my first ARF build and the instructions are a big vague in areas?
Did you glue the centre joint of the wings together?
What CoG and flying weight did you end up with?
Jaz
kittykatjaz is offline Find More Posts by kittykatjaz
Old Jun 10, 2011, 06:07 PM
Rangers Lead the Way
Joined Mar 2010
This has to be the nicest Spit model out there in the .60 and over size. Gorgeous plane.
TTRotary is offline Find More Posts by TTRotary
Old Jun 11, 2011, 02:41 AM
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Hi guys, sure you can ask questions, i will try to help.
Yes the wings are glued togheter, and the CG is by the recomended location from the manual, but a little more forward, i know by the hard way that its very very hard to fly this plane with the CG to far back, if you are not sure.... make sure its atleast by the recommended location.
Another notice is the flaps, we started with about 30 degrees, but it wasent stable with this, we gained the rates to 60 degrees and it became much more stable in landing, but you have to hold up the nose some.
I can also say that we have had a few flights with this nice plane now, and with the sound module and a speaker located in the nose, wow what a great experience it is to make a pass by the field, and to taxi along the runway is now very cool and fun
But we have had to load it with alot of weight to get the CG, we are actually now flying it with 12s 5Ah cells, and the sound system in the cowl with an extra 3s 4200 pack to get the CG, the plane still flyes good but we have the power as a 50cc gas engine. We therefore decided to go ahead and get the 50cc ESM Spitfire that arrived yesturday, we will put the sound and motorsystem in that instead.
Old Jun 11, 2011, 02:45 AM
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
I have some movie material that i will try to get up on youtube later.
Old Jun 11, 2011, 08:47 AM
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Movie
Spitfire (1 min 49 sec)
Old Jun 11, 2011, 01:36 PM
Joined Mar 2010
Thanks for the info Jocke. That is too bad about the weight though. If you had to do the build over, are there any tricks you can think of that would remove tail weight? Also wondering how far forward (how close to the motor) were you able to get the batts? Finally,what AUW and wing loading did you wind up at? Thanks
Old Jun 11, 2011, 03:54 PM
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Battery was as far front to the firewall as possible, and in the cowl both speaker, a 900g motor and a 3s 4200LiPo, actually everything was as far in front as possible, we even had to remove the superlight Mejzlik carbon spinner with cooling, to a much heavier low cost aluminum spinner (280g!!!) to get the CG where we wanted it, this ended up to be heavy and we powered up to 50cc power, so the idea to keep this system in the 72" version seemed unfair when there is a 50cc 2,26m version. I dont know about the AUW, but its hard to build it light when you need so much weight far up front, thats another story with a heavy gas motor.
If i would do it agin, and perhaps we will remake this version, we will redesign the firewall so its possible to have packs in under the motor and as much as possible in the cowl.
Old Jun 12, 2011, 01:03 AM
Joined Mar 2010
Or maybe a longer XVIII style cowl, though that would not match the rest of the plane. I'd really like to get this model down the road but I hate heavy builds.
Build Log ESM Spitfire XIV. Lynxman Electric Warbirds 517 Jul 28, 2014 06:17 PM
Sold 5 New AR7000 Receivers 72.00 each shipped rino Aircraft - General - Radio Equipment (FS/W) 3 Mar 12, 2011 06:53 PM
Sold 1/5 Scale ESM Spitfire rice rocket Aircraft - Fuel - Airplanes (FS/W) 5 Feb 16, 2011 07:22 PM
Question ESM YT 72.5" Spitfire Gaz-b Fuel Warbirds 5 Nov 27, 2010 08:01 PM
Wanted ESM Spitfire Canopy 72.5" propicts Aircraft - Fuel - Airplanes (FS/W) 0 Oct 23, 2010 10:34 AM
