Old Feb 16, 2005, 11:48 AM
That Freeking Laird Guy
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Hinge tape
What's the best hinge tape these days and who sells it? I want something that will not yellow with age and that will stay stuck to my wing. I have some of that fancy 3M stuff that is supposed to be the shiznitz but it comes off in the Cali desert heat and it is not real clear either. Need clear or white tape that will stay stuck!
TFLG
TFLG is offline Find More Posts by TFLG
Old Feb 16, 2005, 04:44 PM
Think Thermals!!!!
SoCalGliderFlyr's Avatar
Costa Mesa, California
Joined Mar 2004
Plastic hocky tape. About $2.50 a roll. Black, white and clear.
SoCalGliderFlyr is offline Find More Posts by SoCalGliderFlyr
Old Feb 16, 2005, 05:08 PM
TFLG's Avatar
Joined Feb 2002
Plastic hocky tape is fine for taping the wing fuse gap. I'm not going to use it as a hinge. The adhesive is not strong enough.
TFLG
Old Feb 16, 2005, 05:13 PM
Think Thermals!!!!
Joined Mar 2004
You've tried it as a hinge???
Old Feb 16, 2005, 05:56 PM
Mr Mootsie
Tim Jonas's Avatar
Pepperell, MA, USA
Joined Jan 2001
3M Blenderm...there is no substitute. Do a search on it here in the Zone.
Tim Jonas is offline Find More Posts by Tim Jonas
Old Feb 16, 2005, 06:05 PM
solo6796's Avatar
United States, TX, Richmond
Joined Aug 2003
I got a roll of bookbinder's tape from the office supply. It has worked real well on ailerons, spoilers, elevators, rudders, and flaps.... I'm almost out. I have had some clear packing tape on the root of my Hawk wings for 2 years to protect the Ultracote from taping the wings to the fuse. It has not yellowed yet and hasn't become gummy or anything flying almost every weekend in the hot Houston summers. The Ultracote has faded, tho... I've used it for spoilers, too.
AJ
solo6796 is offline Find More Posts by solo6796
Old Feb 16, 2005, 06:20 PM
Go get them Meg!
lrsudog's Avatar
Cabin 21...
Joined Jan 2001
I second the Blenderm, although 3M "Scotch" brand makes a tape that I like even more, when I can find it. The only difference I can see is that Blenderm is "Flat" and the repair tape is "Glossy".
lrsudog is offline Find More Posts by lrsudog
Old Feb 16, 2005, 07:42 PM
wakumann's Avatar
Canada
Joined Jul 2003
Brian,
The Ski industrie (Sport shops ) uses Scott industrial tape (don’t know the No) for the Ski edges, which is reported also perfect for hinges
A few German F3B guys using it on there Models, so it should be good .
Cheers
Thomas
wakumann is offline Find More Posts by wakumann
Old Feb 17, 2005, 09:39 AM
Rochester, MN
Joined Nov 2002
I like Blenderm. Neither the freezing temperatures of MN nor the heat and humidity of Florida bother it. Only problem is I have to order it by the box since the local drug stores dont carry it. I gotta try some of the "clear repair tape" that Irsudog suggested when I run across some.
evan is offline Find More Posts by evan
Old Feb 17, 2005, 10:08 AM
Think Thermals!!!!
Joined Mar 2004
How about 3M 600. Comes in a 3/4" wide roll.
Old Feb 18, 2005, 07:32 AM
Wallingford, Ct
Joined Sep 2001
Blenderm is sold by Dubro.
Al M is offline Find More Posts by Al M
Old Feb 18, 2005, 07:52 AM
LSF V,LSF Secretary,AMA Lifer
Robglover's Avatar
Huntsville
Joined Oct 2003
If you want to buy Blenderm from Dubro I have a bridge for sale that you'll be very interested in.
I go to the first aid section in Wal Mart and get the same stuff for about a tenth the price. Johnson and Johnson sells some stuff that is the same as far as I can tell.
If you want some better tape try Don Richmond at hilaunch.com. He sells a roll of tape that won't stretch (at all), has a very tenacious adhesive, and is thinner than Blenderm. Sunlight does something to the adhesive that makes it set up like epoxy resin. If you leave the roll laying out in the sun it's a bad thing, but if you store it in a drawer and put the plane out in the sun after the tape is on it's a good thing. A roll will last enough planes to wear out anybody's wallet. It's better for the bigger and faster planes than Blenderm. The blenderm is great for hand launch stuff and things like my Tensor.
Robglover is offline Find More Posts by Robglover
Old Feb 20, 2005, 11:39 AM
Love my Pike Superior!
averen's Avatar
Austin, TX
Joined Jul 2003
I picked up some Graupner hinge tape at my LHS a while back. They don't carry it anymore but it was VERY nice.
The tape is extremely thin and almost invisible when applied to a surface. It would stretch if you pulled really hard. It would not stretch much though.
Jared
averen is offline Find More Posts by averen
Old Feb 20, 2005, 12:19 PM
TLAR Black Belt
ejett's Avatar
Athens, LA, United States
Joined Apr 2002
I like the Graupner hinge tape too. For a while, it was way too expensive. It is available in white and clear. 32 feet (what metric size is that?) for $3.50 for the white and $5.50 for the clear. I don't know why the premium on the clear.
http://www.hobby-lobby.com/miscitems.htm
EJ
ejett is offline Find More Posts by ejett
Zagi Owners, Check Your Hinge Tape StructuresGuy Foamies (Kits) 11 Nov 12, 2001 04:12 PM
Using Hinge Tape As Opposed to Hinges on speed 400 and 600 planes Joe Elston Electric Plane Talk 21 May 16, 2001 05:20 PM
Hinge tape - Packing tape OK? ChrisD Power Systems 8 May 05, 2001 12:35 AM
Why won't this !#&%# hinge tape stick? DeaninMilwaukee Electric Plane Talk 5 May 03, 2001 02:19 PM
hinge tape cenman Electric Plane Talk 6 Apr 25, 2001 04:54 PM
