Old Mar 31, 2015, 12:38 AM
martig is online now
Find More Posts by martig
Estonia, Harju, Tallinn
Joined May 2012
2 axis gimbal on a fixed wing
I would like to use a 2 axis (yaw & pitch) brushless gimbal on an airplane. The 2 axis controllers I have seen are all for roll & pitch. I would just mount the gimbal 90 degrees so that roll would become yaw.
Could a 2 axis controller handle that or would I need a 3 axis controller with one axis disabled?
martig is online now Find More Posts by martig
Old Mar 31, 2015, 06:49 AM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
I'm pretty certain that you need a 3 axis gimbal, as the yaw axis can't be stabilised by self-leveling, as the others are. Anyway, why would you want to forego either pitch or roll stabilisation on a plank?
GordonTarling is offline Find More Posts by GordonTarling
Old Mar 31, 2015, 09:29 AM
Joined May 2012
The gimbals used on airplanes usually are 2 axis. I don't really need the horizon to be horizontal. I would just like to gimbal to stabilize the camera enough so I could use 10x zoom and track objects on the ground.
Help! Vector RTH problems on fixed wing andriyco Eagle Tree Systems 5 Feb 16, 2015 09:24 PM
Build Log Stopped in for a visit....Fixed wing with 3 axis gimbal power Aerial Photography 34 Jan 13, 2015 09:56 AM
Discussion Does a 3 axis inverted gimbal exist for fixed wing? Nucc10 FPV Equipment 19 Aug 16, 2014 02:32 AM
Discussion BGC 32 bit board on 3 Axis GoPro Gimbal with 360 degree rotation on Yaw Axis myrcmodel Multirotor Electronics 0 Jun 17, 2014 10:19 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
