Old Mar 08, 2013, 07:48 PM
reefpilot is offline
Find More Posts by reefpilot
reefpilot's Avatar
New Zealand, Canterbury, Christchurch
Joined Aug 2009
Question
Ignition Tachometer problem?
Hi guys I have a 26cc RCG gasser with the Pegasus electronic ignition.
Now I am trying to add the mini tachometer that connects to the wire from the sensor to the ignition unit, now with the tachometer connected you have no spark at the sparkplug unplug the tach meter and you will have a spark why?
On the other hand start the engine and then plug in the tach meter its working fine. Can someone please explain.
reefpilot is offline Find More Posts by reefpilot
Old Mar 11, 2013, 12:04 PM
tpasztor is offline
Find More Posts by tpasztor
tpasztor's Avatar
United States, TX, Lake Jackson
Joined Aug 2011
Here is a solution to your problem. Put a switch between you Tach and your ignition. When you need your Tach then turn it on. I use a hand held myself.
Regards
tpasztor is offline Find More Posts by tpasztor
Sold RCEXL Tachometer and RCEXL Optical Kill Switches NEW Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 29, 2013 10:40 PM
Sold RCEXL Tachometer New in package Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 10, 2013 01:36 PM
Sold Model avionics heli tachometer ddrummer508 Aircraft - Electric - Helis (FS/W) 1 Jan 03, 2013 08:53 PM
Sold RCEXL Ignition, Tachometer, Optical kill switch Timing tool Green Fuel Boy Aircraft - Fuel - Engines and Accessories (FS/W) 0 Nov 02, 2012 06:49 PM
Help! Problem with Philip Sun Tachometer faulcon DIY Electronics 11 Apr 29, 2008 05:39 PM
