Old Nov 19, 2011, 06:50 AM
Victory Pete is offline
Find More Posts by Victory Pete
Rhode Island USA
Joined Aug 2010
Question
Some Helis fly like a plane?
Hi
I have been flying Helis on my Phoenix Simulator. I have an MCX and a CX3. I just sold a Blade 400 so I could get the Blade 450 soon. I am still a beginner with these. How come some Helis fly like a plane, I only need to use the elevator and aileron stick, and some (like my helis) need also the rudder to turn the nose into the direction of the turn.
VP
Victory Pete is offline Find More Posts by Victory Pete
Reply With Quote  (Disabled)
Old Nov 19, 2011, 09:02 AM
zadaw is online now
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Originally Posted by Victory Pete View Post
Hi
VP
If your gyro is set on "heading hold" mode, you must use rudder to complete a turn. if your gyro is set on "rate more", then you can fly like a plane with elevator and aileron only. So it basically depends on your gyro setting which you can change.
zadaw is online now Find More Posts by zadaw
Old Nov 19, 2011, 09:05 AM
Rhode Island USA
Joined Aug 2010
Thanks for the reply, so it is tweakable for all helis? I am also wondering how to set up my DX8 so I can reverse the pitch of the rotors, I think I am ready for (intentional) inverted flight.
VP
PS Is it the DX8 I adjust or the Heli in Phoenix?
Old Nov 19, 2011, 10:37 AM
zadaw is online now
Hong Kong
Joined Jan 2010
VP
It is tweakable for almost all CP helis. The only exception I know is the MCPx whose gyro is non adjustable and in heading hold only. There is a switch on the transmitter (either channel 5 or channel 7) where one position is normally used for "heading hold" and another for "rate mode"
As for inverted flight, you will probably need to set up parameters at the simulator as well. As I do not have a DX8i. I don't know what is the best way to do it.
Old Nov 19, 2011, 11:49 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
VP
Inverted flight uses the "idle up" mode on the transmitter.
This changes the motor pitch curve from kinda linear from low pitch to high pitch with rpm, to a v-shape.
http://www.rcheliwiki.com/Idle_up_mode
There should be an explanation of the programming in your manual.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Nov 19, 2011, 12:09 PM
Rhode Island USA
Joined Aug 2010
Thanks for the replies. I see how in Phoenix I can switch the Gyro between the 2 modes. What are the uses for both modes? Also on a real Heli is the Gyro either one or the other or can it be infintely adjustable between the 2 modes.
VP
Old Nov 19, 2011, 12:16 PM
zadaw is online now
Hong Kong
Joined Jan 2010
VP
The gyro sensitivity setting is normally between 0 to 100. A setting of 70 or above is normally in "heading hold" mode. You may wish a try a setting of around for "rate mode". However, you will have trouble taking off from the ground in rate mode and so it is best to take off in "heading hold mode" first before switching.
Old Nov 21, 2011, 11:43 AM
Rhode Island USA
Joined Aug 2010
How do I set the "Idle Up" mode on the DX8?
VP
Old Nov 21, 2011, 08:41 PM
wetwolf is offline
Find More Posts by wetwolf
Quit asking ???s, get a Quark!
wetwolf's Avatar
On a 20ft ladder with a 20ft stick beating an airplane out of a tree. In Spokane, WA.
Joined Oct 2006
He's on a sim. I think he can afford a couple crashes to learn how to take off in rate mode.
wetwolf is offline Find More Posts by wetwolf
Old Nov 23, 2011, 04:54 AM
KDS700E is offline
Find More Posts by KDS700E
Joined Nov 2011
Are there some plane fly like a heli?
KDS700E is offline Find More Posts by KDS700E
Old Nov 23, 2011, 06:02 AM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
Oh that stinks, I've been flying CP in the sim in "bank and yank" fashion. So I may not be able to fly like this if my gyro does not support the other mode? Guess it's not too hard to learn. Have to figure how to switch it in Clearview.
shahram72 is offline Find More Posts by shahram72
Old Nov 23, 2011, 06:14 AM
Rhode Island USA
Joined Aug 2010
I have been practicing flying in both modes, I prefer "Yank and Bank". But can appreciate the precision of "Tweaking the Nose"!
VP
Old Nov 23, 2011, 06:09 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
VP
Don't know.
The manual for the DX-7 mentions Idle up, but that's about it.
From the Blade CP manual, the throttle and pitch curves in Idle Up look like this..
In operation on the ground with the throttle advanced 1/2 way, engaging I.U. results an instant increase in rotor rpm, and if the pitch stick is forward, the heli is pushed down hard... if the pitch stick is aft, the heli will leap off the ground!
Be careful..
I never got to where I had an opportunity to use I.U. in the air....
Old Nov 23, 2011, 07:07 PM
Rhode Island USA
Joined Aug 2010
Don't know.
Be careful..
How come you never got to use IU in the air? Shouldnt the stick be down, towards you for it to push the heli into the ground if it is still sitting on the ground? If you push the stick away from you doesnt it then go up?
VP
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 07:31 PM
Discussion Smart Bird, Plane that fly's Like a Bird,,, WOW!! daboz Dynamic Soaring 5 Aug 20, 2011 01:29 AM
Sold For sale Some electric helis MSR, Heli max and Walkera! Pics Added!!! tc3wins Aircraft - Electric - Helis (FS/W) 2 Apr 12, 2011 06:59 PM
Alert Helis do fly like SOME airplanes!..read on.... rcflyer563 Mini Helis 6 Apr 11, 2005 11:32 AM
Here's The New AP Plane I'm Building...Would like Some Opinions On Wing Design Randy Due Aerial Photography 68 Feb 23, 2004 02:38 PM
