Old Dec 16, 2014, 02:05 AM
Manila, Philippines
Joined Jul 2004
Pickit2 ver 2.61.....can not program PIC 16F88 on certain Hex files.
Guys, have you encounter this......I am developing a simple data logger using PIC16F88.
Normally, I usually put a no. of my program say datalogger1.hex, when i add a new feature I add a higher no. of my program say datalogger2.hex .
I tried to download a new program datalogger2.hex to PIC16F88 , it alway produce verify error on address 0, but when I the older program datalogger1.hex it alway program successfully.
I have use another PIC16F88 same result, this mean the chip is ok.
The New program is shorter than the old one cause I remove some of the feature.
Could there be a problem with my PICKIT 2 version 2.61 ?
I never encounter this problem using PIC16F877, almost all my project I use PIC16F877 ....... I guess, If I can not resolve this issue, I just need to go back using PIC16F877.
lazy-b is offline Find More Posts by lazy-b
Old Dec 17, 2014, 03:52 AM
United Kingdom
Joined Nov 2014
I have had this on a 'f88, turned out to be the pgd and pgc pins, my addition to the code was using timer 1 with an external xtal, if you configure the external osc for timer 1 it messes up the pgd and pgc pins and you cannot program the pic, pgc and pgd are the xtal osc pins.
A jtag type programmer will still erase the pic so you can start over.
Dr peppers is offline Find More Posts by Dr peppers
Old Dec 18, 2014, 08:24 AM
Manila, Philippines
Joined Jul 2004
Dr pepper, thanks for your reply........
Anyway, I was able to make it work, by just using a last know working program, then adding a single statement one at a time then compile it to hex and flash it to PIC16F88......I was trying to catch which statement is the culprit.
I guess, there still some bugs on PIC Simulator IDE version 6.91 . I am using its Basic Compiler.
Old Dec 18, 2014, 08:40 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, Ellion
have a look here http://www.microchip.com/forums/m303686.aspx
have a merry christmas
Alain
Acetronics is offline Find More Posts by Acetronics
Help! where can i find an english ver. of this file here? wmc 2012 off the cd crash8384 Multirotor Talk 0 May 26, 2012 04:13 PM
Discussion PIC 16F59 and PICKIT2 Clone programming possible. nemoskull DIY Electronics 3 Jul 04, 2011 02:49 AM
Discussion PIC HEX file truffaldino DIY Electronics 16 Mar 04, 2010 03:57 AM
Question AF109 PIC: Can I wired 2 PIC in parallel in order to switch its charging program ? rkhoo Batteries and Chargers 2 Aug 27, 2008 11:07 PM
my P16PRO can program 16F84 but can not work on 16F877A lazy-b DIY Electronics 9 Jun 02, 2005 08:53 AM
