Old Nov 24, 2014, 02:00 AM
Velko Velkov's Avatar
Joined Sep 2007
Human powered ornithopter
Velko Velkov is offline Find More Posts by Velko Velkov
Old Nov 29, 2014, 05:03 AM
Joined Sep 2007
Unlocking mechanism
Old Nov 29, 2014, 07:14 AM
Zurich
Joined Apr 2006
In general, due to the power/wt "problem" of humans [vs creatures & machines specially evolved/designed for self-flight], it seems obvious that the only real way to have human-powered flapping flight is to store energy pre-flight. Or while gliding.
The storage can be electrical/chemical [rechargable batteries] or mechanical [compressed air], etc.
MANY solar powered special-purpose cars use this technique, storing solar-electrical power while stationary and "resting" before starting off!
Else the only human-power will be restricted to running before taking off from a cliff/mesa as a non-flapping glider.
xlcrlee is online now Find More Posts by xlcrlee
Old Nov 29, 2014, 04:10 PM
Joined Aug 2014
Lee is right.
Quetzalcoatlus northropi is similar in size and weight to a human powered glider (330 pounds, 36 foot wingspan). Gliding performance is slightly better than an albatross, but Quetzalcoatlus has 25 to 30% flight muscle vs. total weight and still has to flap about 85% of the time when operating as a flap-glider in no-lift conditions (when unable to extract lift from the atmosphere). So, a human powered ornithopter a little more efficient than an albatross would require about 90 pounds of human flight muscle to stay aloft.
JimC3 is offline Find More Posts by JimC3
Old Nov 30, 2014, 04:15 AM
Joined Sep 2007
Unlocking mechanism - variant
Old Nov 30, 2014, 05:40 AM
Joined Sep 2007
Originally Posted by JimC3 View Post
... and still has to flap about 85% of the time when operating as a flap-glider in no-lift conditions (when unable to extract lift from the atmosphere).
I have not observations of Quetzalcoatlus flight.
Old Nov 30, 2014, 06:15 AM
Zurich
Joined Apr 2006
The only so-far successful human-powered flying has been done by Olympic-class bicyclist athletes flying [driving!] huge ultra ultralight fixed-wing aircraft .... in GROUND EFFECT. Which is not "really" flying! The ground effect extends one-half wingspan above the surface, which is why the huge wingspan was needed to overcome the Kremer prize minimum flying-height requirement.
Further, the propeller-propulsion is far more efficient than flapping and it obviously impossible for living creatures to have rotating shafts/axles, although a hummingbird's "shoulder" starts to approach that, but within a cone much reduced from true 360 rotation.
http://en.wikipedia.org/wiki/Human-powered_aircraft
http://archives.chicagotribune.com/1...s-by-own-power
Old Nov 30, 2014, 06:37 AM
Joined Sep 2007
The thread is HUMAN POWERED ORNITHOPTER
Old Nov 30, 2014, 07:01 AM
Zurich
Joined Apr 2006
and ....?
Old Nov 30, 2014, 07:05 AM
France, PACA, Marseille
Joined May 2010
Originally Posted by xlcrlee View Post
The only so-far successful human-powered flying has been done by Olympic-class bicyclist athletes flying [driving!] huge ultra ultralight fixed-wing aircraft .... in GROUND EFFECT. ]
And also Human Powered Helicopter
Atlas Human-Powered Helicopter - AHS Sikorsky Prize Flight (1 min 45 sec)
Of course within Ground Effect
nono1928 is offline Find More Posts by nono1928
Old Nov 30, 2014, 07:08 AM
Joined May 2010
And the forum is about RC
Old Nov 30, 2014, 07:12 AM
Zurich
Joined Apr 2006
Very sorry for any and all confusion or misunderstanding, Velko, but my "point" was clearly, very clearly stated in Post #3 and confirmed in Post #4!
That is, regardless of how clever the mechanical and aerodynamics of any human-powered Ornithopter, until someone makes/creates a new kind of "post-human" with new and GREATLY improved muscle/wt output, the only likely way to fly such an Ornithopter will be to pre-store energy or add it during pure gliding flight .... which the operator can actually put in by him/herself [by peddling, or whatever]. Like winding a rubberband by hand in a freeflight model, as with the classic TIM-bird, which is, ultimately, HUMAN powered [assuming one does not use an electric winder!]
Lee
Old Nov 30, 2014, 07:43 AM
Joined Sep 2007
http://www.rcgroups.com/forums/showt...ed+ornithopter
Old Nov 30, 2014, 08:44 AM
Joined Dec 2013
Props may be more powerful, but more efficient? No way.
Also, integrating prop drive system, and energy storage system worse so, adds weight and requires huge wingspan to compensate as seen in the snowbird.
Lose the prop and go to direct muscle drive and rely on running start and you can get airborne, and leave the ground behind. You should build it Velkov!
Skepticism on human powered ornithopter is very rational and well placed. However, it will be proven wrong.
Only flap when you need to
pteronaut is offline Find More Posts by pteronaut
Old Nov 30, 2014, 08:46 AM
Joined Sep 2007
and ....?
Comments ... ???
Discussion Human powered ornithopter with asymmetric wing Velko Velkov Ornithopters 20 Dec 15, 2013 06:06 AM
Discussion Human powered ornithopter, new try seagull10 Ornithopters 24 Nov 23, 2013 12:20 PM
Discussion Human powered ornithopter with passive articulated wing -simple variant Velko Velkov Ornithopters 0 Nov 13, 2013 02:53 PM
Discussion Human powered ornithopter with passive articulated wing and assistant spring Velko Velkov Ornithopters 41 Aug 16, 2013 06:09 AM
Discussion Successful Human Powered Ornithopter mlbco Ornithopters 95 Dec 12, 2010 10:11 PM
