Old Sep 29, 2014, 08:47 PM
United States, TN, Cleveland
Joined Oct 2013
Cheerson CX-20 Bigshark
The main CX-20 thread mostly deals with the "open source" and "Quanum Nova" models.
I am starting this thread to discuss issues more specific to the Bigshark (BigFlyShark) model.
To begin, I ordered the open source model and got the Bigshark model by mistake.
After getting some help from Banggood support I was able to calibrate the compass.
Since then I'm glad I got the Bigshark model.
It makes an excellent aerial video platform.
Here is the compass calibration demo from Banggood support:
CX-20 Bigshark Compass Calibration (1 min 9 sec)
sureshot__ is offline Find More Posts by sureshot__
Old Sep 29, 2014, 09:06 PM
Joined Oct 2013
CX-20 Bigshark - USB connection to a PC
First, this connection works on my XP portable, but not on my XP desktop.
I think my desktop is missing some C++ dll's?
Anyway, on the portable, it works.
When I made this demo, the CX-20 had a Mobius camera strapped on the GoPro mount.
CX 20, Bigshark version, FC to PC connect. (revised) (7 min 6 sec)
The software and manual may be downloaded at:
http://www.bigflyshark.com/Home/Product/SharkX8#
Select the support tab.
Old Sep 29, 2014, 09:20 PM
Joined Oct 2013
A little reverse engineering & testing
When RTL is selected, or is triggered by lost TX signal:
1) The CX-20 will climb if it is below the return altitude,
2) Then yaw to the heading it remembers from when it was armed,
3) Then it flies backwards to its armed location,
4) Then it descends rapidly if it was above the return altitude,
5) Then it lands slowly from the return altitude.
If you keep flying after the low voltage alarm blinks & beeps, the blink & beep frequency will get faster.
Then at the next (landing) voltage point, it will land at where it is.
I have switched on RTL at that point and it looked as if it were going to try to climb & RTL.
This seemed too risky on an almost dead battery, so I switched back to GPS loiter & let it land.
The Safety zone altitude and range work as advertised.
In the US and many other countries, the legal max altitude is 400 feet (122m).
I currently have my max range set to 350m. I have not tested the TX that far yet.
Old Sep 29, 2014, 09:37 PM
Joined Oct 2013
So - After 3 months of flights, some crashes and repairs, some mods and accessories, I currently am flying:
CX-20 Bigshark
9443 props
accessory jacks relocated
skid rubbers relocated
Mobius w/lens A
Modified 2-axis gimbal
5.8Ghz FPV downlink
7" screen ground station
Old Sep 29, 2014, 09:42 PM
Joined Oct 2013
Has anyone been able to slow the yaw rate so video pans look smoother?
I have tried yaw sensitivity settings of 100, 50, and 20, and I can't see much difference.
16 The Lodge at Westmore aerial views (5 min 42 sec)
Old Sep 30, 2014, 11:51 AM
United States, TX, Johnson City
Joined Jul 2014
Thanks for starting this thread. I am very interested in this version of CX-20.
The other thread has turned into a tinkerers dream while this one hopefully will be more of a RTF/stable option.
I am looking at this and other quads for a stable video platform.
goatman1 is online now Find More Posts by goatman1
Old Sep 30, 2014, 11:57 AM
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
I will follow this thread since the Flying3D X6 & X8 have also a BC FC....
Software is probably identical ...
Flying3D X8 ground station software demo (7 min 35 sec)
SeByDocKy is online now Find More Posts by SeByDocKy
Old Sep 30, 2014, 04:49 PM
Joined Oct 2013
https://www.youtube.com/watch?v=F7_D58cb-6Q
Other than the window size, the screens look identical.
I posted a comment on your video asking about yaw rate.
Maybe post a link back to here from your youtube video.
If I was shopping for a quad, the X8 looks very good.
Old Sep 30, 2014, 06:01 PM
United States, CO, Thornton
Joined Sep 2014
I'm glad I found this thread, I too was supposed to get the open version and ended up with the BigShark. At first I was upset, but since I'm only interested in aerial video and photography maybe it's not such a bad thing after all.
So my question is where do I get the software to upgrade the FC?
I actually just unboxed the CX20 today, but it was windy so I didn't want to risk a maiden flight and crashing it. I'm kind of nervous, this is my first quad and I've read about the fly aways, my plan is to get comfortable with it before I strap on a $400 GoPro.
I also bought a Arris CM2000 Gimbal, is there a place to just directly plug it into the FC for control and power?
dronenewb is online now Find More Posts by dronenewb
Old Sep 30, 2014, 10:56 PM
Joined Oct 2013
Yes, this model makes a great aerial video platform.
For me, the GoPro was too expensive and had too much barrel distortion.
The normal lens Mobius camera makes stunning images fo $80.
Even after slightly lossy post-processing with "ProDRENALIN" to straighten barrel distortion, I'm happy with the results.
Play the video in post #5 at full screen, and you will see what I mean.
The software link is under the demo video in post #3.
The accessory jacks on the bottom will supply 12v for the gimbal and 5v servo for the tilt.
Initially I mounted the gimbal base on 12mm stand-offs to clear the jacks.
I since have relocated the jacks to the side, and the gimbal base directly on the bottom. (see post #4)
I mostly fly in GPS mode.
If I make a mistake, I center the sticks and it just hangs there, even in the wind.
Other than testing, I have only used RTL twice.
Once, I lost sight of it in the sun.
The other time, I was framing a shot in the FPV screen, and the quad was behind a tree.
Old Oct 01, 2014, 09:21 AM
Joined Sep 2014
I already have a GoPro Black Edition, maybe I would be better off selling it and getting the Mobius since I don't ever use it anyway.
I missed the software link the first time I visited the page, I thought they were all pdf files, got it installed now though! For whatever reason the update button does nothing when I click on it.
Thanks for the info on the gimbal, after a few flights (hopefully today) I'll get that installed and working.
I plan on only flying in GPS mode as well, I'm don't have any desire to become aerial acrobat and don't care about speed at all, actually would rather have it go slow so it's easier to control. Luckily I have a huge grass field to practice in...away from people and animals!
I also tried the compass calibration like in the video to no avail, the red blinking light never turned yellow on my mine, has anybody got this to work?
Old Oct 01, 2014, 09:25 AM
Joined Sep 2014
Might be nice to add a version history to the top of this thread since there doesn't appear to be one on BigFlyShark's website. I'm on 1.29 and the latest is 1.31 and it says it added 6S battery support and OSD.
Old Oct 01, 2014, 09:50 AM
SeByDocKy's Avatar
Joined Dec 2012
I will try to reduce yaw rate and make a test ASAP. The FY-X8 is not bad at all too... but not the perfect quad . I like it anyway
Old Oct 01, 2014, 12:49 PM
Joined Oct 2013
Yaw rate tests 150, 200, 250
I do not see much difference.
The results vary only by my ability to keep the stick close to null.
CX-20 Bigshark - Yaw comparason (1 min 9 sec)
Old Oct 01, 2014, 01:00 PM
Joined Oct 2013
The settings change in real time. The bottom left button turns back to green as they complete
The update button is only for future firmware updates.
I had to watch the demo video very closely at first before I saw that SWA was being toggled just 0-1-0-1-0-1 until the LED changed.
Discussion CX-20 Cheerson Auto Pathfinder Dogdude Multirotor Talk 12860 Today 11:32 AM
New Product Cheerson CX-20 CX20 Auto-Pathfinder FPV RC Quadcopter With GPS RTF Aaron qin Multirotor Talk 130 Dec 18, 2014 07:19 AM
Sold Cheerson Cx-20 NIB bjyahr Aircraft - Electric - Multirotor (FS/W) 3 Jun 05, 2014 03:39 PM
Discussion SIMPLE MODIFICATION OF CAMERA MOUNT PROVIDES WITH THE KIT OF CHEERSON CX-20 quadcopte nickden Mini Multirotors 0 May 23, 2014 09:12 AM
For Sale CX-20 Cheerson Autopathfinder Quad monser63 Aircraft - Electric - Multirotor (FS/W) 12 May 16, 2014 09:49 AM
