Closed Thread
Old Jun 06, 2014, 04:07 PM
Grass stain your plane.
RAlanBoyle's Avatar
United States, IL, Chicago
Joined Feb 2011
Motor Destroyed Itself
Take a look at the picture below. This Omega 130 was about a year old, recently I installed it on my PA AddyX; I flew it about 10 times with no issue, then today It threw off the prop (prop adapter w/prop/spinner) in flight. I was able to land the plane with no damage and I figured I must have forgotten the locktite. I opened the cowl and found the motor in this condition.
Any idea how this could have happened?
I was running 45a esc, 12x6apce (not over amped). It was reverse mounted (so the broken part was attached to the firewall.)
Thoughts?
RAlanBoyle is online now Find More Posts by RAlanBoyle
Old Jun 06, 2014, 04:42 PM
tacx's Avatar
United States, MI, Macomb
Joined Apr 2009
Seems as thought the motor frame could not take the load imposed on it.
May be a case of a faulty manufacturing issue.
tacx is offline Find More Posts by tacx
Old Jun 06, 2014, 04:47 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
near Nijmegen, Netherlands
Joined Feb 2001
Did you balance your ;prop?
Did one blade break off?
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jun 06, 2014, 04:50 PM
RAlanBoyle's Avatar
Joined Feb 2011
Prop was balanced and did not break.
Old Jun 06, 2014, 05:47 PM
What tree?
Rampage's Avatar
Yucca Valley, California
Joined Aug 2005
That's really weird. Especially given that the part that broke isn't really under any rotational load. The bearing is taking all of that.
Rampage is online now Find More Posts by Rampage
Old Jun 06, 2014, 06:16 PM
RAlanBoyle's Avatar
Joined Feb 2011
Ya, it basically looks like I went nose first into the runway. That would make since, but I didn't.
Old Jun 06, 2014, 06:27 PM
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
cheap metal.
Kenny Sharp is online now Find More Posts by Kenny Sharp
Old Jun 06, 2014, 08:13 PM
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Screws came loose and the remaining tight one carried all the load.
Kimber is online now Find More Posts by Kimber
Old Jun 06, 2014, 08:22 PM
RAlanBoyle's Avatar
Joined Feb 2011
That is an interesting theory. It was held on with two bolts and they were both tight when I took the motor off for the picture.
Old Jun 06, 2014, 08:37 PM
Canada
Joined Nov 2000
So you are claiming that that broken off mount was Not bolted to the firewall ?
What grabbed it to tear it off then ??
Possible ..as is anything, but seems as seriously unlikely.. from here.
Clearly there are unmentioned factoids.
Regardless: Best not to repeat the same mistakes :-)
Bare is offline Find More Posts by Bare
Old Jun 06, 2014, 08:47 PM
RAlanBoyle's Avatar
Joined Feb 2011
The broken off part was bolted. The broken leg was still holding tight to the bolt and the firewall, just broken off from the rest of the motor.
I understand the hesitancy to believe I am telling the whole truth but this is all of the information. I'd rather not make the same mistake a second time, that's why I'm asking if anyone knows what my mistake was.
Old Jun 06, 2014, 09:48 PM
DustBen's Avatar
United States, NE, Kearney
Joined Dec 2011
A lot of things aren't making sense.
I'm out...
DustBen is offline Find More Posts by DustBen
Old Jun 06, 2014, 10:42 PM
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
The motor was bolted directly to the fire wall, no X mount? One bolt was over tightened and cracked
the housing. Is there a mark on the firewall where the motor was mounted???
Old Jun 06, 2014, 10:53 PM
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Over torqued screws maybe?I would check the firewall too.
Dang I think slow.
Ron H is online now Find More Posts by Ron H
Old Jun 06, 2014, 11:30 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
I don't understand the confusion and disbelief here. The story is obvious enough, isn't it?
The prop adapter/spinner assembly wasn't tightened enough, or simply couldn't grip the polished shaft, and gradually worked its way out toward the end. When it got there, it moved heavily off-axis for a fraction of a second, imposing an enormous momentary side load on the shaft before leaving the model behind. That load torqued the rest of the motor laterally toward the side with the leads. Since the opposite side wasn't secured with a screw, it was free to move away from the firewall. At this point, the non-screwed arm on the lead side was not able to bend back toward the bell the way it wanted, so the end of that arm became a fulcrum. Look at the firewall (presumably plywood?) for a large dent of some kind at that location. That'll be the spot which absorbed the force it took to tear the one arm completely loose and severely bend the opposite one, since both of them were attached with steel screws that evidently overpowered the thin aluminum of the backplate.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Closed Thread
Discussion taro hex destoys itself on takeoff after 3degree motor tilt mod nathanroberts Multirotor Talk 51 Feb 19, 2014 09:40 AM
Help! [Video]Did i destroy my motors? MortenBN Multirotor Electronics 3 Feb 11, 2014 02:05 PM
Discussion Quadcopter one motor shutdown by itself deansrk Multirotor Talk 0 Jan 30, 2014 09:01 PM
Discussion Blade SR destroyed itself in flight - fix? Or replace with a t-rex 450? Wiskey Electric Heli Talk 29 Aug 03, 2010 11:54 PM
Poll Which one wont destroy itself mcx or cx2/3 forrest225 Coaxial Helicopters 50 Apr 24, 2009 03:26 PM
