Old Jan 29, 2009, 10:58 AM
gotwind is offline
Find More Posts by gotwind
U.K
Joined Jan 2009
A unique request - 3 blade prop as wind turbine
Hi.
I run the renewable energy company gotwind
I am looking at making a small wind turbine and need some help in finding the correct 3 blade propeller, used in reverse to power a home made alternator, swept area diameter of around 12"
I have seen good results with the Graupner 11" x 7 (I don't actually know what these numbers refer to, diameter i assume??)
I have also tried a 'Master Airscrew' 11" x 6 two blader which caught the wind better, Im assuming the second number refers to pitch?
So I guess a 12 x 6 three blade propeller would be a good step forward?
I'm looking for 1000 rpm in a 10 m.p.h windspeed.
Any help appreciated.
Ben.
gotwind is offline Find More Posts by gotwind
Old Jan 29, 2009, 12:14 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
Ben,
The first number is diameter in inches, the second is Pitch (6 shoudl signify that the prop would move 6 inches forwar per revolution if their wsa no slipage)
You might need to go to a 16x?? prop (I dont use props above 12" for my planes)
ATIS is offline Find More Posts by ATIS
Old Jan 29, 2009, 12:40 PM
The_Fuzz is offline
Find More Posts by The_Fuzz
The_Fuzz's Avatar
Calgary, Alberta
Joined Jul 2007
You could use something like this:
http://www.hobbycity.com/hobbycity/s...idProduct=4351
4 blade
The_Fuzz is offline Find More Posts by The_Fuzz
Old Jan 29, 2009, 01:14 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
Model props are rather inefficient at being turned by the wind. You'd want to get a "SF" style and re-pitch it to a higher pitch. (if they make a SF style 3-blade at 12 inch dia)
As to the desired RPM... "Pitch speed" is appx rpm/1000 * pitch. So aiming for 1000 rpm at 10 mph. 10 inch pitch is pretty close. The drag of whatever you are driving will give you a bit less actual rpm.
So you will want appx 9.5 inch pitch.
A "glow style" (probably easier to find) will not be as efficient for your purpose as the SF style electric prop.
APC would make the props to order, and would be cost effective if you want a lot of them.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Jan 29, 2009, 01:46 PM
gotwind is offline
U.K
Joined Jan 2009
Great answers, thanks.
Wow this is an active forum, I run my own forum on renewable energy DIY ideas, but it's not as busy as this one.
From what I can gather, the lower the pitch number, the more angle at the root of the blade, that was why the number '6' started up quicker than the '7' pitch prop? - I know diameter has a huge impact on performance (with wind turbines), so maybe a 14" or 16" diameter might be better.
I am U.K based, and am completely new to RC, so terms like "SF" and "glow style" prop are a little lost on me.
Thanks again.
Old Jan 29, 2009, 02:58 PM
ATIS is offline
Member 120mph Club
ATIS's Avatar
SF is slow fly prop...the blade tips are wider for more thrust which in turn should turn with less wind.
glow style props are heavier and thicker so that would be bad in terms of weight.
Old Jan 29, 2009, 04:23 PM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Take a look at these GWS slow fly props. They are very light weight and are very wide and go up to a 15 x 10. They are two bladed but maybe two 90 off might work.
http://www.bphobbies.com/view.asp?id=V576658
Maybe something like a toy pinwheel might also suit your needs.
Rickochet is offline Find More Posts by Rickochet
Old Jan 29, 2009, 04:43 PM
gotwind is offline
U.K
Joined Jan 2009
I think the 'slow fly props' are the way to go, maybe..
I guess, I am after the reverse of thrust, let the wind take care of that - the airofoil section with ready made props appeals to me, 3 bladers in particular - it reduces gyroscopic forces in yaw (turning out of the wind) from an even bladed prop - 2/4/6 e.t.c
Odd numbers of blades is the norm with wind turbines, 3 or even 5 blades.
Old Jan 29, 2009, 08:54 PM
Xpress.. is online now
Find More Posts by Xpress..
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
Basically, SF is Slow Flyer. Glow Power is, well, glow power, or basically IC (Internal Combustion) engines, that require fuel to run. Glwo is different then gas, as it's octane level is higher then gasoline.
SF props work excellent on slower turning motors, which is important for slow flight for models. They grab the air pretty good, when being powered. The air should grab them well on a ball bearing supported shaft.
Xpress.. is online now Find More Posts by Xpress..
Old Jan 29, 2009, 11:15 PM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
another two cents
Not that I am an expert, but wouldnt a "squirl cage" work better on a small power generator? wind direction ceases to be an issue and the surface area to the wind increases dramaticly.
Squirl cage: like the blower inside of a hairdrier.
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Mar 29, 2009, 10:12 PM
ktaylor is offline
Find More Posts by ktaylor
Oh look I'm bleeding...
ktaylor's Avatar
USA, IL, Rock Island
Joined Dec 2005
Lower pitch will be better for a prop that is pushed by the wind. Prop with a 6 inch pitch at 1000 RPM will have a pitch speed of 5.68 mph A prop with a 7 inch pitch at 1000 RPM will have a pitchspeed of 6.628 mph So in a 10 mph wind, with a perfect world & no prop slip, you would see 1508 rpm the 6 inch prop would turn at 1760 rpm. You'll see less than that on a generator because of the friction of bearings & the load from generating electricity. Pitch should be quite low for wind turbines, whereas the diameter of the swept area is the more important factor. That gives you the torque to generate more current. The pitch gives you the RPM to generate a higher voltage.
Never have looked into micro turbines before since the amount of electricity being generated is very small, but it would be an interesting school science class project.
ktaylor is offline Find More Posts by ktaylor
Old Mar 29, 2009, 10:14 PM
ktaylor is offline
ktaylor's Avatar
Joined Dec 2005
Oh, one other thing, assuming you can't find a commercially made propeller to suit your need, you can always take 3 props & make this.
Old Mar 29, 2009, 11:01 PM
Joined Mar 2005
Actually, you can make the 3-blade prop from just 2 props... and have one blade left over.
Works OK for relatively low RPM and electric drives. Don't do it for a glow engine. Should be fine for the wind powered application.
Old Mar 29, 2009, 11:35 PM
woodsy is offline
Find More Posts by woodsy
Woodsy
Drouin, Australia
Joined Sep 2003
Ok, heres a couple of things that i'll throw in.
HC has some 3 blade props in RH and LH rotation although the bigest one is 9 x 7 so may be a bit small for what you require.
There are also several 'variable pitch' set up's available which would allow you to 'tune' the pitch for what you are trying to achive.
you could also run through a gearbox which may help
woodsy is offline Find More Posts by woodsy
Old Jul 23, 2015, 08:16 PM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
That's what came to mind to me. If I were to do any DIY wind generator I would go vertical.
http://www.remnet.com/Wind%20Energy/Hesperia1.jpg
Neighbor down the street has one of these on his garage:
http://cleangreenenergyzone.com/wp-c...nd-turbine.jpg
davidmc36 is online now Find More Posts by davidmc36
3-Blade Prop Options Greg Covey Scale Kit/Scratch Built 19 Oct 09, 2002 09:16 PM
GWS 9x7 3 blade prop Rooster287 Electric Plane Talk 0 Jul 15, 2002 02:34 PM
Beaver on 8 720 Nimh & 3 blade prop GoodTill Parkflyers 0 Jul 06, 2002 11:29 AM
gws 3 BLADE Prop now available at..... Bleriot Parkflyers 5 Feb 16, 2002 03:10 PM
2 blade v. 3 blade prop planeluv Scale Kit/Scratch Built 1 Dec 12, 2001 10:15 AM
