Old Dec 29, 2003, 07:48 PM
magoo51@pacbell is offline
Find More Posts by magoo51@pacbell
magoo51@pacbell's Avatar
United States, CA, Brentwood
Joined Dec 2003
Yippee!
Zagi XS
Anybody out there flyin that new Zagi-XS from Trick RC?
I have.....and it's a blast!!! It helps to have a Mega 16/15/3 in it but boy is she rigid! No Wing flap here!!
I am addicted to Zagi's!!!!!
magoo51@pacbell is offline Find More Posts by magoo51@pacbell
Old Dec 29, 2003, 08:32 PM
RICH S is offline
Find More Posts by RICH S
Joined May 2000
Re: Zagi XS
My friend's son is also flying one with a Mega 3 turn, they seem a bit faster than the original Zagi, and still glide pretty good. Another friend has one and he's a beginner, don't need to worry about broken canopies like I did when I started flying these. It just mushes the nose a bit and keeps going.
RICH S is offline Find More Posts by RICH S
Old Dec 29, 2003, 08:36 PM
Joined Dec 2003
Hey Rich,
What Battery is your friend's son using with his 3-Turn?
Old Dec 29, 2003, 09:05 PM
RICH S is offline
Joined May 2000
Zagi Batts
He as well as myself are using CP-1300's, 1700's and 2000's. I only get about 4-5 mins on the 1300's. We're using MAS 5.5X4.5 props. This set-up is ballistic, they go straight up out of sight.
Old Dec 29, 2003, 09:50 PM
Joined Dec 2003
MORE ZAGI
How many cells?....8? Even the new 8 Cell 1800mAh NiM's (that comes with the XS) runs my Mega for 10-15 minutes (I do a bit of "thermal") before I coast in.
I use the 5X5 Carbon from Zagi
Old Dec 31, 2003, 12:15 AM
Shem is offline
Find More Posts by Shem
Malaysia
Joined Dec 2003
magoo,
Have you tried your Mega /3T with Varioprop 6". It really cooks better then the carbon prop from trick.
Shem is offline Find More Posts by Shem
Old Dec 31, 2003, 09:28 AM
Joined Dec 2003
Shem,
What controller are you using? I did not think that the 3 turn could spin a 6 inch prop without overloading my Phoenix 25. But I will try anything once.
Old Jan 01, 2004, 06:57 PM
Shem is offline
Malaysia
Joined Dec 2003
magoo,
I use a CC Pheonix 35 and I set the pitch to 3" on the Varioprop. Pulls about 30 amps.
I also have a /4T, and with the Varioporp set at 2.8" pitch it still cooks better then the carbons.
Happy New year.
regards
shem
Old Jan 01, 2004, 11:23 PM
Joined Dec 2003
Shem,
Thanks for the tip! I will have to try one of those Variprops.
Happy New Year!
What battery do you use?
Old Jan 02, 2004, 02:34 AM
frederm2002 is offline
Find More Posts by frederm2002
CheapBatteryPacks.com
Beaverton, OR
Joined Dec 2002
Shameless plug
Just came across this thread.
We just brought in a Ton of 1800 4/5A cells for the Zagi XS. These will match the KAN 1800 exactly for way less.
$22.00 for an 8 cell pack.
www.cheapbatterypacks.com
click on Plane packs. It is in the middle (hint: filter by "A" sized cells with 8 cell counts) or use the customize pack option: Select CBP-1800 4/5A, Offset Brick w/Deans 14awg wire.
Thanks !!
frederm2002 is offline Find More Posts by frederm2002
Old Jan 02, 2004, 09:08 PM
Shem is offline
Malaysia
Joined Dec 2003
Magoo,
3S2P Etec for /4T and 3S4P for /3T. For weight savings, I am considering Irate 2600's. But the cost is somewhat steep.
frederm,
I am considering some alternate packs for my XS. Maybe the HR1950FAUP will work for my /3T setup.
Old Jan 04, 2004, 09:47 AM
Joined Dec 2003
Shem,
I have never heard of the Irate 2600. Where can I learn about these batteries? My 3T Mega smokes on the 3S2P Thunder Power I cannot imagine the 4P! 8400 mAh??? @ 11.1 volts....WOW!
That 1950 AUP Nickel Metal from Cheap Battery Packs (Mike will give you great service!) is also a great pack!
The real bargan here is Cheap Batter Packs is selling the stock battery 4/5A 1800 mAh NiMs for $22.00!!! That beats the crap of paying $160.00 for the Thunder Power 3S2P although the performance ofr the LiPo is ummatched!!
Magoo
Old Jan 04, 2004, 04:15 PM
777 is offline
777
Find More Posts by 777
777
Bought at a price.
Winfield, Kansas, United States
Joined Jul 2002
Originally posted by frederm2002
Shameless plug
Thanks !!
Am I reading you to say that this will work with a Mega system? How would they compare with the 1700AUP's?
777 is offline Find More Posts by 777
Old Jan 04, 2004, 07:28 PM
Shem is offline
Malaysia
Joined Dec 2003
777,
I have not used the 1800 4/5A's before but I guess it will work. I have checked the amp draw of a standard 400 motor from trick with the standard KR1700AU pack and it draws 13-14 amps if my memory serves correctly.
This is what I have checked before
KR1700AU + Speed 400 = 13-14 amps
KR1700AU + Mega 5T = 14 amps (if memory serves)
KR1700AU + Astroflight 020 = 18 amps
Old Jan 06, 2004, 11:37 AM
atlav8r is offline
Find More Posts by atlav8r
atlav8r's Avatar
Cumming Ga
Joined Apr 2002
Astro 020
I am flying the Astro 020 on all of my Zagi planes and have been having a blast with the 020 on the XS. All of my XS customers have been having great things to say about this new plane and the Astro is just putting smiles on everyones face.
atlav8r is offline Find More Posts by atlav8r
Zagi XS and Li Poly 11.1 v RocksterP&W Power Systems 21 Jan 01, 2004 11:19 PM
Question zagi xs brushless help RickNick Foamies (Kits) 1 Dec 30, 2003 11:58 PM
New Zagi XS 777 Foamies (Kits) 9 Dec 28, 2003 04:47 PM
Hows the Zagi XS with 1100mah 8-cell nimh packs? lagcisco Foamies (Kits) 0 Dec 17, 2003 09:36 PM
Zagi XS goofy_txn Foamies (Kits) 27 Dec 11, 2003 11:40 PM
