Old Mar 04, 2010, 07:48 PM
BACKEMFNRG is offline
Find More Posts by BACKEMFNRG
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
B/L ESC's for 1/8 What do you run?
Hello,
I was curious, what others run for an esc in their 8th bikes?
I run an old Mamba 25A esc and a Lehner 1010 5455Kv/3200Kv motor (love the ability to rewire the motor!).
It seems ok but, I was wondering if i would get better low speed stability with an OTO/ZH esc?
I'm dumb as dirt when it comes to throttle curves etc on the Mamba software, maybe I could get a picture of a proper throttle curve to help at lower speeds??
Anyway, maybe I can get enlightened...
I know the Sensored units are very nice, just a bit pricey since I already had the motor and esc before the bike.
Q2. What choices are there for sensored motor/esc? Just Novak???
tks
BACKEMFNRG is offline Find More Posts by BACKEMFNRG
Old Mar 04, 2010, 10:45 PM
test driver is offline
Find More Posts by test driver
newcastle Australia
Joined May 2004
I personally. Run either the venom 5200kv or hobbywing equivelant. I do have a tekin esc and 8000kv motor which I do like the torque curve of (esc that is) as I use it with a mamba 4200 as well. I have never tried a sensored system in the small bikes so I can't comment on them.
Eden
test driver is offline Find More Posts by test driver
Old Mar 04, 2010, 11:11 PM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
Never tried a sensored 1:18th system either. I use Mamba 25, Mamba Micro Pro, and SAE (OTO stock).
Guidoracer is offline Find More Posts by Guidoracer
Old Mar 04, 2010, 11:30 PM
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
Is there allot of difference between the Mamba and SAE from OTO?
Old Mar 05, 2010, 12:09 AM
Guidoracer's Avatar
United States, CA
Joined Nov 2004
I have not used the SAE and either type of Mamba on the same platform, so I can't really give you a qualified answer. The SAE has never left the OTO, and I use Mambas on the GPV-1, Half-8, and Travis P bike. What I can say is that the SAE is a very smooth sensorless speedo in the OTO. The Mamba can be raw power, if programmed that way, or docile and smooth, if programmed that way. The Mamba is way more programmable than the SAE, but again, I haven't used the SAE with anything but the stock 4050kV Align motor and the OTO.
Old Mar 05, 2010, 12:30 AM
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
The Align motor is hybrid outrunner/ inrunner isn't it? I think it is 6 poles too, maybe?
Old Mar 05, 2010, 10:09 AM
rhino131 is offline
Find More Posts by rhino131
rhino131's Avatar
Joined Jun 2004
i have been running the novak mongoose system in my gpv it is very smooth and has huge brakes that dont fade only problem is the size of the can limits my gearing choices in that bike due to motor can to contersprocket clearance
rhino131 is offline Find More Posts by rhino131
Discussion GPV-1 warning crapy service alert and 5 things you should do before you run nofuelheli Motorcycles 56 Aug 29, 2011 12:07 PM
Question What would you do, and what are my options? EricJ320 Trader Talk 16 Mar 05, 2010 10:25 AM
Discussion What do you look for in a Lipo charger? RamboFlier Batteries and Chargers 10 Mar 05, 2010 08:54 AM
Poll just for fun what do you prefer 1/5 or 1/8 scale bikes and why ?? rcphreak Motorcycles 26 Feb 28, 2009 01:25 PM
