Old Jan 26, 2006, 09:18 AM
Joined Jan 2006
Question
Lipo resistance
How do you get the resistance for a particular lipo cell? ie thunder power or flight power?
Can you put a multimeter across the +ve and -ve to measure the rersistance or is that a bad idea
ionx is offline Find More Posts by ionx
Old Jan 26, 2006, 09:25 AM
Huntington Beach, CA
Joined Dec 2004
If you can find a way to measure amps (by using a watt meter or something else) you can figure the voltage drop at a given number of amps, and calculate the resistance that way. Voltage drop = Amps x Resistance
TMetalMan is offline Find More Posts by TMetalMan
Old Jan 26, 2006, 09:26 AM
Slovakia
Joined Apr 2005
Very bad idea, even more advanced (and expensive) DVM will burn.
Resistance of the cell is internal into the cell that has some voltage across it - You can imagine that it is resistor in series with batery, with no possibility to get inside this pair.
Two principles are used - first is to measure resistance using AC (pulsing to/from cell) current, often at 1kHz. This could tell You the number cloce representing real "resistance".
Second principe is to put known load onto cell/pack and measure how deep its voltage will drop (comparing to its no load voltage). This is not so exactly scientific, however can tell You more about pack/cell ability to "be usefull".
In general, Lipo resistance is very low, expected numbers are 10-50 miliOhm per cell.
coro is offline Find More Posts by coro
Old Jan 26, 2006, 09:31 AM
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Also the resistance is not static. It appears higher when the cell is cold and may change as the cell is discharged. The reason is that some of the resistance is due to current flow thru materials like we are used to measuring, but some is due to the chemical nature.
feathermerchant is offline Find More Posts by feathermerchant
