Old Dec 24, 2005, 05:05 PM
France
Joined May 2005
9 motors 30g with stats, where is the best ?
Hello
I'm looking for a 30g outrunner
I find this :
HiModel A2406-32T KV1150 TP Series Outrunner Brushless Motor
KV 1150 33g 15$
http://www.himodel.com/en/rc_hobby/electric_1224.php
APC10*47SF 4300RPM 7.2V 6.8A 310g
2207 DIY Brushless Motor
KV ?? 32.5g 19$
http://shop.eflypower.com/product_in...roducts_id=564
8x6SF 2S 5A 4900RPM
Stats :
http://www.rcgroups.com/forums/showthread.php?t=332739
Volare 2815M
KV 1100 33g 35$
http://shop.eflypower.com/product_in...roducts_id=571
2 cell 8x4 7100 RPM 3.7A
2 cel 8x6 6100 RPM 5.4A
2 cell = 7.4V ??
stats :
http://www.eflypower.com/modules/new...5#forumpost505
MP Jet Outrunner Brushless Motors AC 22/7-45D
KV ?? 26g 37$
http://www.hobby-lobby.com/brushless-mpjet.htm#AC
A20-34S - 27mm Outrunner BL motor (1500kv)
KV 1500 28g 37$
http://www.aero-nuts.com/product_inf...roducts_id=258
EP7035 7.72v 4.70A 268g
MicroDAN 2505 3D Series
KV 1030 34g 55$
http://www.e-foamies.com/Brushless/M...oduct=MD25053D
APC9*4.7SF 6.8V 5.3A 313g !!
stats :
http://www.rcgroups.com/forums/showthread.php?t=346373
HYPERION Z-2205 46
30g 55$
http://www.aircraft-world.com/shopexd.asp?id=2796
GWS9x4.7SF 6.8V 6.7A 5295RPM
AXI 2204/54
KV 1380 24.5g 66$
http://www.hobby-lobby.com/brushless-axi2204.htm
APC7x4SF 7.2V 212g 4.7A
GWS8x4HD 6.8v 240g 4.75A
stats :
http://www.flyingmodels.org/motortes...xi_2204-54.htm
http://www.rcgroups.com/forums/showthread.php?t=342078
http://www.rcgroups.com/forums/attac...hmentid=630768
Moteurs Donuts-Models 2C/24/280
KV 1380 24.5g 74$
http://www.donuts-models.com/pages/m...donutspag.html
9x4.7 2S 330g
so, where is the best (quality/price)
FRED
FredJust is offline Find More Posts by FredJust
Old Dec 24, 2005, 11:31 PM
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
I've got a couple of Microdans, strong and smooth, they get my vote!
mike3976 is offline Find More Posts by mike3976
Old Dec 25, 2005, 02:01 AM
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
You missed a couple... at least
Little Screamers
Custon CDrom
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Dec 25, 2005, 08:59 AM
Edmonds Wa. (Seattle)
Joined Nov 2003
Little Screamers
Custon CDrom
Larry
Ya I am still around!
Scott
littlescreamers.com
23g 12a $49.99
Littlescreamers is offline Find More Posts by Littlescreamers
Old Dec 25, 2005, 05:16 PM
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
Will turn Larger Props, cause its 25mm, you know
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
It's all out war!!!
fly_boy99 is offline Find More Posts by fly_boy99
Old Dec 25, 2005, 05:49 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
If weight is important, the Axi is the lightest motor in your list. It is also a proven performer in Shockie style planes.
My non-Lexan Little Screamer with a mount weighs exactly the same as an AXI.
The AXI is a lot quieter than the aptly named Screamer.
Pat Mackenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 26, 2005, 06:24 AM
France
Joined May 2005
ok
there are 22mm and 25mm
there are 9 and 12 tooth stator
the best (for indoor flying, slow with big thrust) is 12 tooth and 25mm ?
I 'm not sure if Hyperrion is a 12 tooth ?
FRED
Old Dec 26, 2005, 07:55 AM
pmackenzie's Avatar
Joined Dec 2002
AFAIK, the Hyperion is a 12 slot LRK motor like the AXI.
Slow with big thrust is not always the best.
With a big prop it is almost impossible to stop the plane from torque rolling in a hover. With a smaller prop and the right plane you can do an anti-torque roll.
My first Shocky had a 2208 (39 gram) motor swinging a 10x4.7 on 2S. Lots of thrust, but a hover was always a torque roll.
When they became available the 2204, although down a bit in thrust, was a much better motor choice. Switching to 3S gets back all the thrust.
Also larger props are heavier. This is important when you are trying to shave a few grams here and there.
If you want to see how a small prop high rpm setup can work check out the Knuffel videos here .
The Knuffel is intended for a sub-20 gram motor swinging a 7" prop.
What plane are you going to use this motor in?
Pat Mackenzie
Old Dec 26, 2005, 08:55 AM
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
What plane are you going to use this motor in? Quote: Pat M.
Agreed! Trying to decide which motor is best without knowing its intended use is like asking which apple makes a better pie, It all depends on the tree!
But, there's allways a selection of prop weights across a given size range
Old Dec 26, 2005, 02:27 PM
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Causemann 240-05
Jocke is offline Find More Posts by Jocke
Old Dec 26, 2005, 05:00 PM
ryanl2006's Avatar
Ames, Iowa
Joined Oct 2002
12 vs 9 slot is something a lot of people stuggle over on which to use. I personally chose to build 9 slot motors to save weight, but the microdans are very nice and can swing very large props with ease.
Indoors you are right you want less pitch speed, but then again you also want to keep your indoor planes light...
I am sure I just confused you even more, but really there is no cut and dry answer.
ryanl2006 is offline Find More Posts by ryanl2006
Old Jan 07, 2006, 05:55 AM
France
Joined May 2005
I buy the Volare 2815
here my test with Emeter
Moteur Volare 2815 (7A/60s max):
HELICE V A RPM Grams
GWS SF 9x4.7 6.6 4.4 4700 240
GWS SF 9x4.7 7.35 5 5040 280
GWS SF 9x4.7 7.26 5.2 5100 290 (timming 30)
GWS SF 8x4.3 7.47 3.6 5890 235
GWS SF 8x4.3 6.53 2.9 5290 190
GWS SF 8x4.3 7.4 3.8 6000 240 (timming 30)
GWS SF 8x6 6.67 3.8 4980 200
GWS SF 8x6 7.4 4.5 5360 235
GWS SF 7x6 6.58 3.1 5330 150
GWS SF 7x6 7.45 3.6 5880 190
GWS SF 7x6 9.91 5.4 7310 300
grams was calc with :
http://www.gobrushless.com/testing/t...calculator.php
It is good ? no ?
FRED
Old Jan 07, 2006, 09:57 AM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
This is rather outdated but might be of some use.
http://www.rcgroups.com/forums/showt...n+small+motors
MicroDAN 2505/10 and the newer Littlescreamers are not in here, nor are the latest CustomCDR Billet motors.
Edit: Here is a link to MicroDAN 2505/10 performance and that of other small motors with 8x4 and 9x5 GWS HD props.
http://www.rcgroups.com/forums/showt...odan+2505%2F10
Here's a link to Custom CDR Single data:
http://www.rcgroups.com/forums/showp...65&postcount=9
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Where is best price for electronic soldering iron & supplies? CheeseWing Electric Plane Talk 9 May 29, 2010 03:36 PM
Where is the best place to buy Hacker motors JPA2002 Power Systems 3 Mar 09, 2004 06:40 AM
Where is the best price on the GWS Tigermoth? Scomis Parkflyers 9 Nov 23, 2001 12:45 PM
Where is the best E-buy for FMA Razor 400? rlt55 Foamies (Kits) 0 Aug 02, 2001 05:30 PM
For 9.6V 1600ma NIMH battary what is the best charge rate and charge time?(more) clchen Parkflyers 1 May 06, 2001 04:23 AM
