Old Oct 16, 2012, 03:08 PM
Jiffy's Avatar
Joined Nov 2005
Motor ESC Hanger 9 sundowner 36 help setup please
Hi guys I have Hanger 9 sundowner 36 but I'm not sure what motor to use (buy), I have a local model shop in the UK where I buy all my motors, could sombody please please help me and give me your views on this.
The model shop I use is
http://www.giantshark.co.uk/brushless-motor-c-25.html
Jiffy
Jiffy is offline Find More Posts by Jiffy
Old Oct 16, 2012, 06:20 PM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
The recommended setup is an Eflite Power 32 motor, either on 4S 3200mAH with a 12x8 prop as the sport setup at around 600W, or on 5S 2700mAh with a 10x10 for speed at about 750W.
That motor has Kv=770 and weighs 200g.
A very close equivalent that I have used and been happy with is the Turnigy G32-770
Good candidate from GS is http://www.giantshark.co.uk/xyh4250-...-p-405282.html Pretty close in spec to the recommended motor, although Kv is a little higher. Several good reviews in the power range you'd want. I'd start with a 12x8 on 4S and check with a wattmeter.
Note that you will probably have to modify the x-mount or fabricate a mounting plate to match the eflite mount spaced holes in the firewall, and you may also have to space the motor from the mount/firewall to match the cowling
scirocco is offline Find More Posts by scirocco
Discussion Hanger 9 sundowner 36 (help) Jiffy 3D Flying 5 Oct 20, 2012 10:58 AM
For Sale Hanger 9 Sundowner 50 wings rotorhead22 Aircraft - Fuel - Airplanes (FS/W) 0 May 30, 2012 08:54 PM
Sold Hanger 9 Sundowner .50 (RTF) SOLD!!!!!! rjstrickjr Aircraft - Fuel - Airplanes (FS/W) 3 May 23, 2012 10:08 AM
Sold NIB Hanger 9 Sundowner 50 ARF - Toledo or SEFF djmoose Aircraft - Electric - Airplanes (FS/W) 4 Apr 05, 2012 08:55 PM
Sold NIB Hanger 9 Sundowner 50 ARF - Toledo or SEFF djmoose Aircraft - Fuel - Airplanes (FS/W) 0 Apr 05, 2012 05:13 PM
