Old Oct 13, 2012, 06:53 AM
Marietta GA.
Joined Jan 2011
Spektrum DX8 battery indicator
Guys, I just got this thing..Is like 5.1 volts normal on the gauge for a fully charged factory Ni-MH pack...? Seems like my DX6 would read like 5.6 or something with the 4AA NI-MH in it....thx..
mazjag is offline Find More Posts by mazjag
Old Oct 13, 2012, 07:08 AM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
If brand new it may take a few charging cycle for the battery to reach fully charge BUT I'm no battery expert.
I can tell you however that a 4.8v pack freshly off the charger could show near 6v and quickly drop around 5.5v and settle there for some time.
Knowing that 5.5 is normal for such pack consider the following. The DX8 as a manufacturing calibration tolerance of up to .3v volt on the display.
So your pack could very well be closer to 5.4v which sounds very normal for such pack. Only way to confirm how much difference you have is to use a DVM and test the voltage while the battery is under the radio's power load.
I would not worry about it, give it a couple of cycle and go from there. If the radio battery doesn't last long enough for you you can always get the lipo upgrade.
freechip is online now Find More Posts by freechip
Old Oct 13, 2012, 07:21 AM
Marietta GA.
Joined Jan 2011
thanks,,,,I`ll cycle a few times and see what happens...
Sold new spektrum dx8 2000mah nimh batterynew spektrum dx8 2000mah nimh battery ohsnap Aircraft - General - Radio Equipment (FS/W) 1 Nov 09, 2012 10:13 AM
Sold $18 shipped! Never even charged stock DX8 Spektrum battery bighead93 Aircraft - General - Radio Equipment (FS/W) 2 Mar 29, 2012 12:19 PM
Sold SOLD - NEW Spektrum DX8 Battery - 2000mAh 4.8V NiMH xxrando Aircraft - General - Radio Equipment (FS/W) 2 Mar 28, 2012 10:55 PM
Discussion DX8 and DX7s Battery Voltage Indicator Difference Dodge DeBoulet Radios 47 Mar 06, 2012 08:34 AM
Sold Spektrum DX8 with new AR8000 DSM2 Rx and Spektrum 7.4 LiPo TX battery crosby Aircraft - General - Radio Equipment (FS/W) 1 Dec 15, 2010 11:54 AM
