Old Aug 09, 2012, 08:53 PM
Joined Aug 2012
Please help!!!
I realize I am new here... and I am in WAY over my head. I CANNOT figure out how to get this thing to fly for ANYTHING... Here's my situation...
Walkera Genius CP
Devo 7
At 0% throttle input, the blades are pitched fully negative, and somehow the pitch is tied to the throttle. I can't get the thing off the ground.
When I CAN get it off the ground, it tail spins uncontrollably, and crashes 2 seconds later.
Is there ANY WAY you guys can point me in the right direction in order to set this thing up to where I can at LEAST learn to fly it? I'm honestly at the point of putting them both up on eBay and forgetting I ever tried getting into this hobby.
EDIT: I realize you guys probably get this a LOT... but I'm coming from a fixed 4 channel, and was pretty good at it, and I THOUGHT I was ready to get into the 6 channel birds and move on. So much for that idea.
PLEASE, PLEASE, PLEASE help.
KMiracle1984 is offline Find More Posts by KMiracle1984
Old Aug 09, 2012, 08:55 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Did you buy it used?
Balr14 is online now Find More Posts by Balr14
Old Aug 09, 2012, 08:59 PM
Joined Aug 2012
Yes... it has been used previously, but the Devo 7 is brand new.
Old Aug 09, 2012, 09:06 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
You are going to have to search for Devo 7 setup for the Genius. The tail spinning isn't likely to be a setup issue. If it spins counter-clockwise, odds are good your tail motor is bad. But, the first thing you need to do is change it to 6 channel mode (switch on the board), make sure you are using low rates and when you plug the battery in make sure the heli is setting on a level surface and you don't mess with it until it's done initializing the gyro.
Old Aug 09, 2012, 09:34 PM
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Actually i bet the tail spinning is his gyro..turned off . So go in to gyro and set it up to i think auto sense and then turn it to around 75% and see if your tail holds. If it still drifts up the % a little bit until it stops
Also try this to get your heli mechanically setup right first as you always want 0 pitch at center stick for a cp helicopter.
Mcpx 0 pitch setup (4 min 42 sec)
Then try programing in something like this into the devo7. The mcpx isnt the same as the genius but the basic mechanical setup is and the flight curves react very similar.
Mcpx as a more beginner friendly FP heli (9 min 28 sec)
indoorheli is online now Find More Posts by indoorheli
Old Aug 09, 2012, 10:20 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Check this out, there are 3 parts.
Walkera Devo 7 TX - Setup Part 1 (2 min 5 sec)
Help! A sensitive plea for help.... David A Ramsey Life, The Universe, and Politics 147 Jun 27, 2012 08:01 AM
Plea for help Wiebelhaus Off-road Cars 0 Oct 03, 2004 11:54 AM
Pleas help recommend charger TheTick Batteries and Chargers 23 Apr 29, 2004 04:06 PM
A Plea for Help The_Giver Humor 3 Aug 30, 2002 07:10 PM
RealFlight g2 Multiplayer pleas help Pablito Parkflyers 0 Apr 27, 2002 08:44 PM
