Old Jan 13, 2012, 04:04 AM
QLD Australia
Joined Oct 2009
High point--C of G--bolt Hole position ???
My home made blades fly OK, but I'am wondering what position people like to put their C of G and Blade Holes in relation to the "Highest point"[max thickness of chord point] of their blades?
My holes are on the "highest point"[apx 30% from leading eadge], and my C of G is apx 10% behind the bolt holes[apx 40% from leading eadge].
They are all balsa blades[no harder/denser wood in LE].
Wondering how other people set theirs up??
Regards, M
minirotor is online now Find More Posts by minirotor
Old Jan 13, 2012, 09:40 AM
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
You want your bolt hole on the highest point, but you want your CG to be in the same spot. So either you need to add weight to the LE of your blades or move your hole back.
My two cents.
Joe
jodini is online now Find More Posts by jodini
Old Jan 13, 2012, 07:25 PM
QLD Australia
Joined Oct 2009
Thanks Joe.
What are the flight results of C of G too far foreward?
And too far back of the bolt hole[high point]?
Regards, M
Old Jan 13, 2012, 10:31 PM
jodini's Avatar
Joined Sep 2004
I think the blades will not center very well. For example if the CG of the blades if forward of the hole, the blades will not swing straight out but instead slightly forward. (I think I have that right). Anyway, you want them close to the hole. You should be able to just add a little strapping tape to the LE to get the CG more forward.....worth a try!
Joe
Help! Bolt hole diameter of 13-14mm Outrunners? boredom.is.me Scratchbuilt Indoor and Micro Models 8 Dec 31, 2011 03:41 PM
AVA C/G Position fudi50 Thermal 1 Sep 13, 2005 06:30 PM
Simprop Liftoff c/g position? graham williams Electric Sailplanes 2 Mar 27, 2005 03:55 AM
Rant AldiJ C of G position Wot4 Slope 4 Jan 27, 2005 06:28 PM
