Old Jun 29, 2014, 05:41 AM
Scratch Builder
AlexanderB's Avatar
Braunschweig, Germany
Joined Sep 2006
Yesterday I took some time to cover the h-stab, elevator and rudder. I have to say it took much more time than expected. I think I worked 4h-5h on that.
But I really took some time and found the results much better than the outer wings which I did years ago ().
I used Orastick scale white which I bought also years ago for the rest of the plane but man, this stuff is heavy. I cannot use it for the rest of the plane. But I neither cannot uncover it without the risk of ruining the rudder. But I certainly will need to find a solution.
Next will be detailing the surfaces: panel lines and access hatches. But this will need some research. I was not aware enough to take pictures of the empennage in total so I only have a couple of pictures where I can barely see some details.
What I found out was that the right and left h-stab / elevator are the same, e.g. one is mounted upside down. I saw that the fairing of the elector tab is on top of one stab and under the stab on the other side. Interesting.
Cheers Alexander
AlexanderB is offline Find More Posts by AlexanderB
Old Jun 29, 2014, 05:47 AM
North UK
Joined Jun 2005
Very impressive DC-9 !
Looks like one of the early short fuselage 'series 10' type DC-9s.
Working flaps and slats as well - very good attention to detail :-)
DH106 is offline Find More Posts by DH106
Old Jun 29, 2014, 05:52 AM
Scratch Builder
AlexanderB's Avatar
Joined Sep 2006
Indeed. If you happen to have a couple of days off, don't miss to read Johns build log
http://www.rcgroups.com/forums/showthread.php?t=208512
Cheers Alexander
Old Jun 29, 2014, 01:06 PM
Scratch Builder
AlexanderB's Avatar
Joined Sep 2006
Very brief update: I did the panel lines and access hatches of the elevators. Used an edding 780 paint marker with a 0.8mm tip. Looks all right to me.
Cheers Alexander.
Old Jun 29, 2014, 02:17 PM
Kootje's Avatar
The Netherlands
Joined Nov 2011
Cheers Alexander.
Hi Alexander, Your panel-lines are looking very good !
Did you also use the silver colour for the less tinted lines?
Had a look at the Edding shop and was looking for a grey colour, but found the silver pen.
I tried several pens, but my lines became too black....
Succes with building, the dc6 looks great !
Regards Paul
Kootje is offline Find More Posts by Kootje
Old Jun 29, 2014, 03:39 PM
Scratch Builder
AlexanderB's Avatar
Joined Sep 2006
Thanks Paul,
It is silver indeed. It took me some time to find this pen. Could be more thin but this is the only one I found not to be too blackish.
Cheers Alexander
Old Jun 29, 2014, 06:24 PM
RiBell's Avatar
Canada, BC, Abbotsford
Joined Jan 2003
Alexander:
Two very well done models.
Looks good sitting outside next to another airplane.
So the next visit your going to get a couple of formation flight pictures?
Rick
RiBell is online now Find More Posts by RiBell
Old Jun 30, 2014, 05:57 AM
It only takes one good idea
dag214's Avatar
Fishers, Indiana
Really cool, and great you are building again.
DAG
dag214 is offline Find More Posts by dag214
Old Jul 19, 2014, 07:16 AM
Scratch Builder
AlexanderB's Avatar
Joined Sep 2006
Hi Folks,
I got a question of how I did this threaded end for the hinge rod. I took a couple of pictures which show it quite well:
1) I used a knurled nut where I screwed the aluminum screw tightly in. This knurled nut was clamped in the lathe to protect the thread. I tried to clamp the screw with the thread directly but - as I thought - that destroyed the thread.
BTW I had to counter the screw with another screw.
2) I drilled a center hole with a special drill.
3) Then I drilled an 1.8mm hole through the entire nut.
4) In order to save material I used a saw (very carefully not to touch the chuck)
5) done. It was easy to get the screw out of the knurled nut.
Cheers Alexander
Old Jul 19, 2014, 07:18 AM
Scratch Builder
AlexanderB's Avatar
Joined Sep 2006
So eventually I call the H-stab / elevator section done. I added the fairing for the outer trim tabs (note that the elevators are symmetrical hence one is on top and the other is on the bottom) and.. added the static dischargers!
Cheers Alexander
Old Jul 19, 2014, 08:59 PM
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
Cheers Alexander
Alexander,
Looks fantastic and glad to see you are able to work on it again. Used to be a full scale pilot and I always wondered what those were on all the control surfaces.
Dave
payne9999 is offline Find More Posts by payne9999
Old Jul 20, 2014, 04:45 AM
Scratch Builder
AlexanderB's Avatar
Joined Sep 2006
Thanks Dave,
I love these little details. My finish-skills are not so well but I think it's OK.
Cheers Alexander
Build Log Pitts S1S for 100 watts scratch build Mike Tully Scale Kit/Scratch Built 73 Nov 24, 2013 10:32 AM
Build Log Tony Nijhuis Douglas DC-3 Dakota kit Build. Basingstoke Roy Scale Kit/Scratch Built 74 Jul 07, 2013 05:25 AM
Build Log Protech Douglas DC 3 (Build) flyingrally Scale Kit/Scratch Built 10 Aug 08, 2010 04:02 AM
Yippee! DC-3 scratch build complete Lowboy Foamies (Scratchbuilt) 4 Nov 28, 2006 07:53 PM
Fokker F-100 scratch build airliner project Igwe Aneke Electric Ducted Fan Jet Talk 35 Jul 07, 2005 06:16 AM
