Old Jul 11, 2014, 01:30 PM
Joined Jun 2010
Hi RCWORKS, I have bin on Vacation for the past 2 weeks but before i left i had evething working just great, one thing with the G540 i set up limit switchs but they do not work is that because i am using GMFC Pro and not GMFC Expert?? Or should that not matter.
Pat
pjf610 is offline Find More Posts by pjf610
Old Jul 11, 2014, 02:45 PM
Disgruntled Member
RCWorks's Avatar
United States, OK, Anadarko
Joined Aug 2003
I don't think GMFC software supported limits, I never use them so I'd have to look.
Straight from the web site...
Limit switches for the GGC USB interface.
Buttons for moving to the zero switch and to the home position.
Beyond that means an email to Gilles...
RCWorks is offline Find More Posts by RCWorks
Latest blog entry: HobbyCNC ProBoard...
Old Jul 12, 2014, 02:25 AM
gm.cnc's Avatar
France
Joined Feb 2006
Originally Posted by foxbox View Post
Please GFMC and MM2001 works with any USB to LPT parallel interface emulated ?
I would use the laptop without MM2001 LPT port.
Thank you for the info
Hi,
You must buy the GGC USB adapter from copaero, and the USB add on from my site
Gilles
gm.cnc is offline Find More Posts by gm.cnc
Old Jul 14, 2014, 11:57 AM
Sherpa
Schwemmer's Avatar
La Quinta, Ca.
Joined Sep 2003
I am calibrating my machine. I have the Hobby CNC foam cutter board and I am running the V.1 USB connector cable. Is it necessary to recalibrate the motor current when changing from full step to half step on the board?
Rick
Schwemmer is offline Find More Posts by Schwemmer
Old Jul 14, 2014, 02:17 PM
Disgruntled Member
RCWorks's Avatar
Joined Aug 2003
Rick
No.
Old Jul 22, 2014, 06:47 PM
Kevin Matney's Avatar
United States, MI, Monroe
Joined Mar 2000
wing larger then table
I have a wing that is 2220 and my table is 1070. will the prg make it in 3 parts?
I set up the wing and it only has a root and tip no mid panel?
I'm using GMCF pro
Kevin Matney is offline Find More Posts by Kevin Matney
Old Jul 22, 2014, 06:57 PM
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Kevin, it's easy...I think it's under panel management, "split current", and it breaks the panel into two panels. We just used it for the first time a few days ago
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Jul 22, 2014, 07:02 PM
Once in a lifetime
danielphantom's Avatar
USA, CA, Temecula
Joined Jan 2009
I believe you can specify what percentage to split it--you can pick 50 50, or 60 40, or whatever you prefer.
danielphantom is online now Find More Posts by danielphantom
Old Jul 22, 2014, 07:38 PM
Joined Mar 2000
But I need it to break it into 3 parts
Old Jul 22, 2014, 07:44 PM
Once in a lifetime
USA, CA, Temecula
Joined Jan 2009
Break it into two panels first maybe 75% 25% then break the big panel into two pieces. Now you have 3 panels.
Old Jul 22, 2014, 08:19 PM
Joined Mar 2000
I tryed but still come with 2 panles
Old Jul 22, 2014, 08:29 PM
Once in a lifetime
USA, CA, Temecula
Joined Jan 2009
Let me try and I'll get back to you
Old Jul 22, 2014, 08:32 PM
Once in a lifetime
USA, CA, Temecula
Joined Jan 2009
OK start with one panel and then click view and select wing
Now split the current panel it will ask what percent pick something like 60
Now you have two panels, click on the left panel and it will become blue
Split that panel. Now you have three
Good luck
And have fun
Daniel
Old Jul 22, 2014, 08:57 PM
Joined Mar 2000
Ok that works. I did it 66.6 then did that part to 50
Old Jul 22, 2014, 09:08 PM
Joined Mar 2000
how do you post a screen shot?
Discussion CNC Foam Cutting problem with GMFC wimmeke CAD/CAM 0 Jan 14, 2010 12:24 PM
Discussion Foam works foam cutting software issue airmcn_3 The Builders Workshop 5 Aug 29, 2008 10:02 AM
CNC software for foam cutting KAMarks The Builders Workshop 0 Sep 15, 2002 08:20 PM
foam cutting software Dinah Power Systems 0 Mar 19, 2002 10:08 PM
Foam cutting CNC software foam_man Foamies (Kits) 10 Sep 08, 2001 08:50 AM
