Old Feb 16, 2015, 01:50 PM
Tinodesis is offline
Find More Posts by Tinodesis
United States, OR, Redmond
Joined Dec 2013
Foot Operated Throttle for Cancer Patient?
Hello,
My friend's 12 year old son has brain cancer. He lost the use of the left side of his body and can no longer play with his R/C cars and planes.
He uses a pistol grip type tx with the small wheel on the side.
Does anyone have suggestions on how to connect a potentiometer to give him a gas pedal to push with his foot? The pedal assembly is something I can have built, just need help with the electronics.
I have a 5K ohm Curtis PB-6 pot box full size electric cars use to signal the controller, but don't know if it's compatible. Any advice appreciated.
Thanks!
Tinodesis is offline Find More Posts by Tinodesis
Old Feb 16, 2015, 11:34 PM
ttabbal is offline
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
If the radio has a trainer port, you could probably feed a PPM signal in there and have it control the throttle. What radio are you working with? I'm sure we can get something going for you.
ttabbal is offline Find More Posts by ttabbal
Old Feb 17, 2015, 12:19 AM
babblefish is offline
Find More Posts by babblefish
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
It might be possible to adapt one of the foot pedals that's used in computer racing car games. I see these things with their steering wheels at thrift shops (Salvation Army, Goodwill) all the time for next to nothing. The base is a good size to prevent moving around too much and the better ones' are weighed. The steering wheel might be useful if he's interested in RC cars too. The pots inside a typical pistol grip transmitter are usually 5K ohm so all you'd have to do is install a connector to the transmitter, disconnect the wires from the internal pot and connect them to this connector. You can then connect the foot pedal to the transmitter through that connector.
babblefish is offline Find More Posts by babblefish
Old Feb 17, 2015, 04:43 AM
phil_g is offline
Find More Posts by phil_g
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
Would a PC-style joystick suit him, with steering via left-right joystick and throttle on the trigger?
phil_g is offline Find More Posts by phil_g
Old Feb 17, 2015, 05:20 AM
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
That's an excellent idea, a joystick for flight simulators. Problem is, on most of them the finger trigger is an on/off switch and not proportional. But, some have rudder control where the joystick itself rotates. This can easily be adapted to throttle control instead, or steering and have the throttle on the joystick; push forward for, well, forward and pull back for reverse. Not sure of exactly which sticks can do this, but I do know that Microsoft made one called the Sidewinder Precision 2. I believe it to be out of production, but widely available on eBay. This article from Tom's Hardware might be of some interest/use:
http://www.tomshardware.com/reviews/...ion,386-2.html
Perhaps someone from the "RC-USB Joystick Files" threads can offer some help: http://www.rcgroups.com/forums/showthread.php?t=508122
I hope that you don't mind that I've already posted a request for help there.
Best of luck with your project. I only wish I were closer in order to give some hands-on help.
-Wes
Old Feb 17, 2015, 11:16 AM
reddiesel is offline
Find More Posts by reddiesel
United Kingdom, England, Luton
Joined Aug 2014
Could just use a normal plane type transmitter and have steering and throttle / brake on the same stick ?
reddiesel is offline Find More Posts by reddiesel
Old Feb 17, 2015, 02:16 PM
prefabu is online now
Find More Posts by prefabu
Kansas City
Joined Dec 2009
If the transmitter you're using already has at least one spare potentiometer (either throttle or trigger), can you just wire the foot pedal's potentiometer in its place with a length of wire (2 meters or so)?
prefabu is online now Find More Posts by prefabu
Old Feb 17, 2015, 04:44 PM
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
Heh, the simplest solution yet...
Old Feb 17, 2015, 08:18 PM
Joined Dec 2013
Thank you to everyone for your input.
I'm waiting to hear from my friend to give me more specific info on the type of transmitter(s) his son has.
I like the idea of just having the throttle, brakes, and steering on one stick.
I also checked the local Goodwill for a foot pedal from a computer game but no luck. If I can find one, it would be nice to swap one 5K pot for another.
I will post when I know more. Thanks again to all of you!
Wanted Kit needed for Cancer patient mrdy2fly Aircraft - Fuel - Airplanes (FS/W) 34 Dec 17, 2014 10:46 AM
Build Log Plane kit gifts help Cancer patient fight boredom! mrdy2fly Balsa Builders 5 Sep 24, 2014 11:58 AM
Discussion It's the Chicago Way: Cancer patient criticizes ZeroCare then gets audited by the IRS Dave Campbell Life, The Universe, and Politics 38 Dec 02, 2013 08:24 PM
Discussion Cancer Patients Lose Shot at Longer Life in U.K. Cuts MtnGoat Life, The Universe, and Politics 104 Nov 21, 2008 02:12 AM
