Old Mar 08, 2014, 07:25 PM
GoNavy is offline
Find More Posts by GoNavy
United States, WI, Rib Lake
Joined Dec 2004
[QUOTE=
GoNavy, your inclined rib, don't know, I think you would have to generate that rib separately, but ask the support section in Compufoil, Eric has been very helpful for a long time on my part.[/QUOTE]
They advised Compufoil cannot generate that special rib.
GoNavy is offline Find More Posts by GoNavy
Old Mar 08, 2014, 07:46 PM
GoNavy is offline
Joined Dec 2004
Originally Posted by portablevcb View Post
Or, make those inner ribs from a much thicker wood, like 1/4 or thicker balsa. Then sand in the angle like above. This also allows a radius to the curve, since full size didn't have really sharp bend on the underside.
But, if you want to keep it really light then, yes, you do have to change the size of the rib a bit. IIRC all it takes is "stretching" it vertically. Use a trig function to find out how much. For 15deg it isn't much.
Yes, function tangenet 15 degree is .2679. If, for example, the maximum "thickness" of our rib was, say, 1.5 inch, the the wedge of balsa would need to be
(1.5 times .2679) .402 inches, on the "bottom.
Make two wedges, glue one to the mating ribs, cut and sand.
Sketch attached.
Question Gull-wing structure i_like_science Modeling Science 4 Nov 23, 2013 05:43 PM
Question how to bend balsa sheet over wing? Higgins909 The Builders Workshop 10 Oct 16, 2013 04:02 PM
Discussion Gull wing design bmblb Electric Sailplanes 1 Sep 23, 2013 01:21 AM
Which thread showed how to bend small balsa ribs? FlyByMike Scratchbuilt Indoor and Micro Models 2 Nov 16, 2002 03:24 PM
