Old Apr 14, 2015, 02:56 PM
Jazz44119 is offline
Find More Posts by Jazz44119
Jazz44119's Avatar
France, Pays de la Loire, Grandchamps-des-Fontaines
Joined Apr 2015
Originally Posted by midelic View Post
jazz,
If you read before pete have futaba.It was advised to install one 10k pullup resistor from PPM signal to VCC 3.3V.That's it .
Thank you for your reply i have already read page 100 to 129 to find an anwser but i don't all understand because of my bad technical and english skills
the resistor will not make a short circuit ? because my ppm is directly connect on the ground
witch circuit is good with this illustration :
Jazz44119 is offline Find More Posts by Jazz44119
Old Apr 14, 2015, 02:57 PM
Thomas.b is offline
Find More Posts by Thomas.b
Sweden, Stockholms län, Stockholm
Joined Mar 2015
Ok I fixed the throttle.Rest of channels 1000-2000 Throttle 1150-2000.
damn that whas fast i did not even manage to get my pizza slize from kichen
THANX midelic.
And thanx also for showing the scope tool that will help me in future.
edit,Today i finaly had time to test latest code and the throttle range is now perfectly dialed in , now i have access to full manual trim when
arming the hubsan x4. thanx again.
Hubsan first FPV (4 min 25 sec)
Thomas.b is offline Find More Posts by Thomas.b
Old Apr 14, 2015, 03:10 PM
midelic is offline
Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
@Jazz
PPM signal cannot be conncected with the ground.I don'T understand why you connected with the ground.Remove PPM ground connection.Anyway The answer is no.2.
midelic is offline Find More Posts by midelic
Old Apr 20, 2015, 06:39 PM
Jazz44119's Avatar
Joined Apr 2015
hello
thank you for your help midelic, i have test many options and at least the one who work is :
ppm connect on the port 3 with a 5k resistor and nothing else.
I have found after many hours of test how run my hubsan !
He is working only with "Hubsan_V2_M328_8Mhz_DX6I.hex"
And the throttle stick is set on my aileron channel (based on this mode http://www.rc-airplane-world.com/ima...ter-mode-2.gif )
How can i inverted the two channel on the module ? because on my radio i can only change the flight mode and not assign channel directly.
Old Apr 21, 2015, 01:27 AM
midelic is offline
midelic's Avatar
Joined Apr 2012
So you donlT know your channel order,
The DX6I version channel order is TAER..and normal version is AETR. so you need a version with ATER?Which tx is that?
O k see attached.
Old Apr 21, 2015, 05:16 AM
goebish is offline
Find More Posts by goebish
I Void Warranties
goebish's Avatar
France, Aquitaine, Bordeaux
Joined Feb 2010
DX6i channel order is TAER, and it cannot be changed.
(except on the latest DX6i maybe, which use the same firmware than the DX9).
goebish is offline Find More Posts by goebish
Old Apr 21, 2015, 05:51 AM
Jazz44119's Avatar
Joined Apr 2015
it work !! thank you for the hex file midelic !
so my channel order is aetr but that weard it cause problem, i have an assan module too and that work fine no reversed channel 1 and 2.
My tx is a futaba t6exap an old tx i have for 7/8 years ^^
Old Apr 23, 2015, 04:50 AM
Chris1990A is offline
Find More Posts by Chris1990A
Joined Apr 2015
Hi
I study your post of DIY hubsan quad ,and obviously you are so professional in Open source world . Recently we finished the update project of open source flying platform --Crazyflie 2.0 . would you mind give me some suggestions about it ? I mean is that a great platform worth to have one .
The details you could see https://www.bitcraze.io/
and http://www.seeedstudio.com/depot/Cra...20-p-2103.html .
Thanks at first about any positive reply !
Chris1990A is offline Find More Posts by Chris1990A
Old May 03, 2015, 02:53 AM
midelic is offline
midelic's Avatar
Joined Apr 2012
Somebody request.
A version for arduino nano/promini(16Mhz) using onboard LED.
Old May 18, 2015, 10:33 PM
scruffy416 is offline
Find More Posts by scruffy416
Joined May 2015
Originally Posted by goebish View Post
Note this is for Taranis X9D(+) Only !
Better safe than sorry so, here's a rev2 with a LDO.
R1 = R2 = R3 = 1K (0805)
R4 = R5 = 5.6K (0805)
Q1 = 2N2222 (SOT-23)
C1 = C2 = 10 µF / 10V tantalum (1206), expensive, probably not mandatory, but better have them, at least C2.
IC1 = AMS1117-3.3 (SOT-223)
headers:
(2x) 1x8 2.54mm pitch male
1x5 2.54mm pitch female
1x9 2.00mm pitch male
requires:
1x Arduino pro mini, any version, goes on bottom
1x A7105-D03 RF module, goes on top
I attached a zip archive with eagle files and .hex firmware (8 & 16MHz versions)
edit: I removed the files because I really don't want to see this sold at goodluckbuy or other chinese shops as that has recently happened with designs downloaded from this forum ... If you want them, please PM
...snip...
Hi,
I'm trying to make this module for a taranis 9xd+ with parts I already have on hand - so I am skipping the promini and trying to make a powered board with an atm328pu and lm1117 thru-hole TO-220 package. I converted the schematics you have on post 1 - then I noticed this post! Is it possible to run your enhanced f/w on the atm328pu?
Also, instead of the 2N2222 SOT-23, I would be substituting a through-hole 2N3904 - according to the OpenLRSng wiki "any small signal NPN" will do so I hope that will work.
scruffy416 is offline Find More Posts by scruffy416
Old May 19, 2015, 05:25 AM
goebish is offline
I Void Warranties
goebish's Avatar
Joined Feb 2010
PM sent.
http://i.imgur.com/KK56N0y.png
http://i.imgur.com/a7tPNye.png
If you want to run my firmware:
- attach the input of the frsky smartport inverter to m328 TX (PORTD.1) pin
If using a A7105-D03 (recommended):
- connect TXEN from A7105-D03 module to m328 PORTC.0 pin instead of +3.3V
- connect RXEN from A7105-D03 module to m328 PORTC.1 pin instead of GND
Then the rest is the same than midelic's schematic.
Mini-HowTo DIY "FlySky" TX/RX module midelic DIY Electronics 2437 May 22, 2015 10:46 AM
Found WANTED: FUTABA TP-FSM 72MHz Synth RF Module svjerk Aircraft - General - Radio Equipment (FS/W) 1 Jun 28, 2013 09:44 AM
Discussion DIY Telemetry System base on TI CC110L RF BoosterPack spy004 DIY Electronics 2 Mar 06, 2013 07:58 AM
Discussion FrSky 2.4G DIY RF Module into JR XP 7202 kriss poppe DIY Electronics 5 Jun 04, 2011 08:39 PM
