Old Jan 05, 2013, 10:12 PM
muhkaydenz is offline
Find More Posts by muhkaydenz
muhkaydenz's Avatar
United States, UT, Provo
Joined Sep 2012
Need help with batt esc and motor combo
I have the turnigy 1800 mah 25c constant 50c burst with the turnigy 35-36c 1100kv 35 amp and am looking at getting a turnigy trust 45 amp esc will this combo work well or will it have issues? I have been reading a lot and there is soo much info I just want to make sure I'm not going to mess anything up thanks!
Links to products:
BATTERY - http://www.hobbyking.com/hobbyking/s...dProduct=20429
Spec.
Capacity: 1800mAh
Voltage: 3S1P / 3 Cell / 11.1V
Discharge: 25C Constant / 50C Burst
ESC - http://www.hobbyking.com/hobbyking/s...ontroller.html
Spec.
Max Motor Current: 45A
Max BEC Current: 3A
BEC Voltage: 5.5v
LiPo: 2~6S
NiMH:5~12cells
MOTOR -
Spec.
Input Voltage : 7.4V~11.1V (2~3S Li-po)
Kv : 1100rpm/V (within 10%)
Current capacity : 35A/30s
Power: 400W+
muhkaydenz is offline Find More Posts by muhkaydenz
Old Jan 05, 2013, 10:42 PM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Wondering 'If it will work' is meaningless without specifying the prop. With no prop it will run happily, but do no useful work. With a 14" prop on 3S, it will overheat. And without the intended application, there is no criteria to assess how well it works.
The motor will work OK on 3S with props up to 13x6.5 or 12x8, at around 34A and 32A respectively. The ESC is rated comfortably above that,. The battery would be running at about 19C at 34A, so should also be OK.
The combination will work very well for 3D models up to about 2lbs, and still excellent aerobatic performance up to 3-3.5lbs. Probably a little light on for the 48" class 3D models, but fine for around 40-42".
scirocco is online now Find More Posts by scirocco
Old Jan 05, 2013, 11:03 PM
muhkaydenz's Avatar
Joined Sep 2012
Sorry I have a radian pro with stock Propeller of 9.75 x 7.5_1 thanks for the help!
Old Jan 05, 2013, 11:12 PM
muhkaydenz's Avatar
Joined Sep 2012
I have 6 servos to run as well will the ESC be able to handle that?
Old Jan 06, 2013, 01:04 AM
scirocco's Avatar
Joined Feb 2001
You will get decent performance with that prop, and scope to increase prop size in future. the battery is well suited to the lower current that prop requires (about 22A).
Make sure the motor shaft is the right size for the folding prop collet adapter,
The BEC should be fine with 6 servos.
Welcome to RCGroups. Just a tip - better off to provide more than less info when asking a question. The application in this case EG pro is always relevant, and you just can't talk power without talking prop size - the motor doesn't 'make' the power on the specs - that's just the max it can handle which depends on voltage and prop size.
Old Jan 06, 2013, 08:46 AM
muhkaydenz's Avatar
Joined Sep 2012
cool thanks!
Discussion best cheap jet/motor,batt,esc/fan combo to go 120mph+ coaldust High Performance 1 Jun 06, 2012 01:02 PM
Discussion please help with motor/esc/batt combo for flyduspider. imdone Multirotor Talk 2 Sep 08, 2011 04:54 PM
Discussion Help with Motor/ESC/Batt combo. panderslap Beginner Training Area (Aircraft-Electric) 3 Nov 25, 2010 11:26 PM
Discussion Need help with motor/esc/battery combo. SoarinJohn Power Systems 2 Jul 02, 2008 06:29 AM
Need help with finding info on Batt\ESC\Motor combos Skawrpion Parkflyers 5 Sep 19, 2003 01:43 PM
