Old Jun 03, 2010, 01:31 AM
Shifty is offline
Find More Posts by Shifty
UK
Joined Oct 2006
How do i land without breaking prop?
Just got one of these setup and am hoping to take it on its first flight today, is there a way of landing without breaking the prop as i can see it causing a problem if its sticking out below the bottom of the wing...
Shifty is offline Find More Posts by Shifty
Old Jun 03, 2010, 03:23 AM
meshyx is offline
Find More Posts by meshyx
meshyx's Avatar
Norway
Joined Feb 2010
If you land with power off at a reasonable speed the prop should get rotated horizontal fairly easily when it hits the ground, and not suffer any damage. Landing on grass will be best for it of course. Also enable motor braking on the ESC so the prop won't be turning when power is off.
I have some wings outfitted with fairly small and stiff props, 4.1 to 5.5 inches, and those are using a collet like on the picture, haven't had any problems with broken props yet.
On some of my slower and larger wings, I am using up to 8 inch slow fly props with propsavers. In a pusher configuration the o-rings don't need to be as tight, so the props can get pushed to the side without much resistance.
Get some cheap props from hobbyking anyway, 3$ for a sixpack, then breaking a prop isn't a problem any longer
meshyx is offline Find More Posts by meshyx
Old Jun 03, 2010, 04:13 AM
Shifty is offline
UK
Joined Oct 2006
Cool thanks, i noticed my prop spins while off throttle but am not sure how to enable motor braking as i didnt get any instructions with the ESC.
Old Jun 03, 2010, 08:49 AM
frednjess is offline
Find More Posts by frednjess
That Guy Who Flies Wings.
La Vista, Nebraska
Joined Mar 2007
Motor braking is bad. It will tend to hold the prop in a specific position when you shut the motor down. You want the prop to spin a bit so it can move out of the way of the ground when you land. It will level itself out on its own. I do touch and go's with my wings on asphalt (no LG) and have yet to break a prop. Just make sure the throttle is off when you land and you'll be fine.
frednjess is offline Find More Posts by frednjess
Old Jun 03, 2010, 08:50 AM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
use a prop saver it usually just breaks the elastic band rather than the prop iuse them on my swift II my toro 900 and my stryker , never broke a prop.
scousethief is offline Find More Posts by scousethief
Help! how do i remove a pinion without a puller foxy29 Power Systems 7 Apr 02, 2010 08:42 PM
Discussion How to take off and land in water without floats... AleG Waterplanes 4 Mar 22, 2010 09:13 AM
Discussion How do you land? tmb55 Beginner Training Area (Aircraft-Electric) 45 Nov 11, 2009 07:57 AM
How To Bend Tiger Moth Elevator/Rudder Without Breaking? segal3 Parkflyers 3 Jan 18, 2002 04:48 AM
How to land without crashing? dshuen Beginner Training Area (Aircraft-Electric) 13 May 16, 2001 08:35 PM
