Old Aug 10, 2014, 04:13 PM
Joined Oct 2010
Power suggestions for an aquila grande and a saggitta xlc
Gentlemen, good day to all. I know nothing about electric motors, batteries bec's, lcd's ac/dc and the list goes on. I would like to power these two planes but don't know where to start. Niether plane has been built yet and both are being built from plans. Lots of room to wiggle. All comments and advice will be appreciated. Oh by the way , i would like these planes to get to altitude smartly.
finshlinerc is offline Find More Posts by finshlinerc
Old Aug 11, 2014, 09:33 AM
Mesa AZ, it's a dry heat!
USA, AZ, Mesa
The basic "rule of thumb" is100Watts/lb will fly well, 150Watts/lb will give "Sparkling performance, 200Watts/lb +, you are on your own!!!
If you look at my blog you will see an article on selecting power systems for models. I may be of help to you.
Iain
rev.iain is offline Find More Posts by rev.iain
Old Aug 11, 2014, 02:43 PM
Joined Oct 2010
Thanks for the rules, but i don't know what that equates to for motor size, battery required and all else related to electrics. Inrunner or out runner. I grew up on nitro and until now was not interested in electrics. These birds come in at about 10 pounds rtf. So i guess 1500 watts is what i will need.
Old Aug 11, 2014, 04:41 PM
banjo328's Avatar
Albuquerque, NM
Joined Jan 2010
I'm assuming that you just need a combo that will haul the planes to thermalling altitude in a reasonable time, and you won't need to go zooming around with loops, etc. with long motor run times.
If that's the case then something like a Turnigy 4250-750 kv , outrunner or equivalent with a 15-16 inch folding prop (Aeronaut is a good one) will do the job using a 3S batt. (4S if you need more oomph) and since you have plenty of room in those fuselages, a fairly big one , 3000 -4000 mill., will give you plenty of run time for repeated climb outs or just cruising around at part throttle.
Less than 500 watts will give that type of performance if you don't need rocket ship climbs, and they would cruise adequately on 300 W.
Over powering is okay but you don't really need it and those big wings were never designed for high speeds and abrupt maneuvers.
http://www.hobbyking.com/hobbyking/s...tors-42mm.html
banjo328 is offline Find More Posts by banjo328
Old Aug 15, 2014, 05:04 AM
FT.MYERS FL.
Joined Mar 2009
E-flite power 25-870kv and a 60-amp s.c. Witha 3-cell 2200-3200 battery. Prop/13-7 or 12x8 with a 4-cell.
CUMICBOY is offline Find More Posts by CUMICBOY
Discussion Aquila VS Aquila Grande 69classic Sailplane Talk 1 Sep 21, 2013 02:00 PM
Wanted plans for an aquila grande and saggitta xc finshlinerc Aircraft - Sailplanes (FS/W) 1 Jul 29, 2012 02:21 PM
Wanted I need a glass fuse for an Aquila Grande fabmaster911 Aircraft - Sailplanes (FS/W) 1 Apr 20, 2011 02:39 PM
Sold Aquila & Aquila Grande kits electric-2000 Aircraft - Sailplanes (FS/W) 3 Feb 24, 2007 03:27 AM
(AQUILA or AQUILA GRANDE) Wing Kit Wanted Dewey12 Aircraft - Sailplanes (FS/W) 0 Feb 20, 2005 11:13 AM
