Old Jun 01, 2014, 12:49 PM
United States, CA, Folsom
Joined May 2014
Help!
Tiny servo movement
Hi
I have some servos controlling the elevator and the rudder. The movement they are creating are tiny. Does anyone have ideas on how to increase the movement?
Spec:
2 12g Turnigy servos
FlySky FS-CT6B Transmitter
DigitalRadio software(I cant use T6 config)
Jero
jerowang is offline Find More Posts by jerowang
Old Jun 01, 2014, 12:59 PM
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
Use the LONGEST arms available for your servos ; then connect your pushrods to the OUTERMOST hole on the servo arms , and the INNERMOST hole on the control horns .
Did you get your radio at HobbyPartz ? For $15 more you can get this computer radio that will use the same receiver .
http://www.hobbypartz.com/79p-t6-6ch-radio-lcd.html
balsa or carbon is online now Find More Posts by balsa or carbon
Old Jun 01, 2014, 01:06 PM
Joined May 2014
I did. Is there any other way to do that with the programming software?
Jero
Old Jun 01, 2014, 02:54 PM
Joined Aug 2010
Jero
I've never used the programming software for that TX , but if you connect to it , look for something called travel adjustment or end point adjustment and increase to the max - it may be as much as 125% or more .
If that doesn't work , you can extend the length of your servo arm by attaching ( with two little screws ) another servo arm to the one on the servo . And you can replace the control horns with horns that have the bottom hole closer to the rudder/elevator hinge line .
Al
Old Jun 01, 2014, 02:58 PM
CAP smasher
compressor man's Avatar
GA,USA
Joined Jul 2010
Make sure your DualRate is not set and limiting your travel.
Chris
compressor man is offline Find More Posts by compressor man
Old Jun 01, 2014, 04:55 PM
Joined Feb 2007
Do the servo arms move about 45 degrees each way?
If it doesn't then its the transmitter that is not giving the full movement.
Quorneng is offline Find More Posts by Quorneng
Old Jun 01, 2014, 06:14 PM
Joined May 2014
Hi
I tried all your idea but the movement is still tiny although it increased a bit by using endpoint adjustment. Are there any other ways?
Jero
Old Jun 02, 2014, 02:47 AM
Staffs, UK
Joined Nov 2003
Define "tiny". What angle do the servos move through ?
Steve
slipstick is online now Find More Posts by slipstick
Old Jun 02, 2014, 07:20 AM
Not always grumpy!!
insomaniac45's Avatar
UK, Eastleigh, Eastleigh
Joined Jul 2010
I have both those radios,
And the programming on the T6 without computer sucks... its so hit and miss, and is not compatible with windows 7, (you have to run it in compatibility mode)
But again, it still sucks.
But remember you dont need alot of throw for elevator, unless your going for full on 3D flight,
I only have about 15 - 25 degree on my elevator for my wot next, and that alone is more than what i need.
insomaniac45 is offline Find More Posts by insomaniac45
Help! Tricopter on Multiwii Pro - No yaw servo movement FIREotter Multirotor Electronics 2 Apr 14, 2014 11:13 PM
Discussion issue with nano cpx - weird servo movement Chris Corbett Micro Helis 3 Jan 17, 2014 01:53 AM
Help! Tricopter on Multiwii Pro - No yaw servo movement FIREotter Multirotor Talk 1 Dec 12, 2013 10:18 AM
Discussion Tarot ZYX-S: No servo movement. v1xiii Electric Heli Talk 2 Nov 24, 2013 11:41 PM
Discussion dh 9116 no servo movement only quick mode works fine in slow mode skipper6567 Beginner Training Area (Heli-Electric) 1 Sep 19, 2013 10:53 AM
