Old Dec 05, 2012, 10:02 AM
kimchiyuk's Avatar
United States, NY, Eldred
Joined Jun 2012
. Do NOT use WD-40 as it will do more harm than good.[/QUOTE]
Just out of curiosity, why is this? I used it for many years in buggy engines with no ill effects and my engines were always corrosion free.
kimchiyuk is offline Find More Posts by kimchiyuk
Old Dec 06, 2012, 08:28 AM
Florida
Joined Aug 2004
Just out of curiosity, why is this? I used it for many years in buggy engines with no ill effects and my engines were always corrosion free.[/QUOTE]
If there is any rust present in the engine, WD40 will tend to break it free and then when you run the engine you have a nice lot of iron particles scouring out your engine, kinda like putting a pinch of sand into your engine and then running it. WD40 is a water dispersant, not a lubrication./
Rodney is online now Find More Posts by Rodney
Old Dec 06, 2012, 11:09 AM
kimchiyuk's Avatar
Joined Jun 2012
If there is any rust present in the engine, WD40 will tend to break it free and then when you run the engine you have a nice lot of iron particles scouring out your engine, kinda like putting a pinch of sand into your engine and then running it. WD40 is a water dispersant, not a lubrication./[/QUOTE]
I guess I can kind of see your point. Personally I don't use ARO as a lubricant. I'm using it to prevent corrosion. Plus ATF is an incredibly strong cleanser. I think it would even break up rust and carbon deposits. I'm definitely not saying WD 40 is the best choice, but considering it stands for Water Displacing...that's really what you are trying to do, or at least one of the main reasons to use ARO...corrosion prevention. I just think that if you use some sort of corrosion prevention method from the start, there should be no rust to break up and cause problems in the first place.
For Sale Rabbit Flight Controller Quad Multi-copter w/ Fixed Hight Direction Care Free RC frozenfloat Aircraft - Electric - Multirotor (FS/W) 1 Oct 08, 2012 07:59 PM
Discussion engine after care MKC Syd Steam Boats 3 Jan 03, 2011 03:20 AM
Discussion After-run / caring for a spare engine jez_uk1 Engines 2 Oct 12, 2007 09:20 AM
Help! Advice on flying and after care of Honey Bee FP mdavenport Micro Helis 4 Jan 28, 2007 09:37 AM
Engine care after crash Flyin' Falzee Engines 4 Oct 07, 2004 10:45 PM
