Old May 30, 2012, 11:55 AM
AECS USN RET. P3 FE
allanp's Avatar
USA, FL, Winter Springs
Joined Mar 2004
Question
Topaz 1st Generation airfoil
I've got a Topaz with a badly warped center section and I want to bag a replacement.Does anybody know for 100% sure what airfoil was used ?? I've seen AG35 and MH 32.
This is 1st gen with one long spoiler
Allan
allanp is offline Find More Posts by allanp
Old May 31, 2012, 08:04 AM
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Allan
I didn't know they sold a vacuum bagged wing.
Kenny Sharp is online now Find More Posts by Kenny Sharp
Old May 31, 2012, 08:10 AM
turn, turn, turn.
Joined Oct 2005
That said, I would think that the vacuum bagged wing would be the MH32 , and the built up wing would be the Drela foils... Otherwise I would think Mark would have vacuum bagged the Bubble Dancer like he did the Supra.
Old May 31, 2012, 08:15 AM
turn, turn, turn.
Joined Oct 2005
Unless by bag, you mean acquire.
In which case, nevermind.
Old May 31, 2012, 09:40 AM
AKA - The "Flywheel"
StevenatorLTFO's Avatar
SOAR Chicago!!!
Joined Jan 2005
I think by bag, he meant that he would bag a foam cored center panel for his.
With that said, I have a first generation Topaz, and it has a bit of undercamber to it, I would say more likely a drela foil. Certainly not an MH-32
StevenatorLTFO is offline Find More Posts by StevenatorLTFO
Latest blog entry: Supra Vertical Stab and Rudder
Old May 31, 2012, 10:08 AM
AECS USN RET. P3 FE
allanp's Avatar
Joined Mar 2004
Thanks,I was leaning toward the AG35.
I'm bagging a center section because a replacement "open bay" center section is unobtainable
Old May 31, 2012, 12:44 PM
Mark Miller's Avatar
St. Louis, MO
Joined Oct 2002
The best thing is to use the current center panel to make templates. I have found that on some of these planes the airfoil is not close to what they say it is. They seem to use the AG series as marketing and not what is really there. Or print a AG35 at that chord and compare.
Mark Miller is offline Find More Posts by Mark Miller
Old May 31, 2012, 03:56 PM
AECS USN RET. P3 FE
allanp's Avatar
Joined Mar 2004
That was "option B",it's now option "A"
Old May 31, 2012, 04:37 PM
3 Sons - Legos and Lift
2motheus's Avatar
Grand Rapids, MI
Joined Apr 2004
While setting up for some repairs on mine I found an old reference sheet that specified AG25. It had a bit of undercamber and matched the center section pretty well. Mine is the full house version.
What I couldn't find is the trailing edge settings for this airfoil. What have you guys done for that?
Thank you,
Tim
OneWinch.com
2motheus is online now Find More Posts by 2motheus
Alert New Generation Plush 6a unable to handle 3s more so than previous generation? daign Multirotor Talk 6 Dec 09, 2011 11:43 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Kites 0 Oct 05, 2011 09:42 PM
Wanted Topaz Wing Ctr section 1st gen undamaged allanp Aircraft - Sailplanes (FS/W) 0 Sep 10, 2011 11:45 AM
Discussion My 1st scratchbuild. Need airfoil advice Matt Gunn FPV Talk 25 Feb 14, 2010 10:23 AM
