Old Mar 19, 2012, 03:00 AM
Joined May 2007
What kind of radio equipments
Hi I am new in Submarine and wish to know what kind of transmitter I can or need to use.
I have been a RC person for quite some while but only in Cars, Sailboat, Fast electric boats and internal combustion engine boats but not submarine.
I wish to know what kind of radio I need to have before I DIVE into the submarine boat.
I understand I can only use AM module transmitter and receiver.
If I cant find any AM 27mhz, 75 mhz transmittal.receiver equipment.
(Non 2.4Ghz radios)
Can I use AM 72 or 40mhz transmittal or receivers ??
Please advice clearly so I can jump into this category !!
chilisoling50 is offline Find More Posts by chilisoling50
Old Mar 19, 2012, 03:54 AM
Ilha Formosa-- TAIWAN
epg800's Avatar
Taiwan
Joined Apr 2010
FM system would be better
basically you need 4ch transmitter and receiver
best regards
Xin
epg800 is offline Find More Posts by epg800
epg800's Avatar
Taiwan
Joined Apr 2010
(Non 2.4Ghz radios)
best regards
Xin
Old Mar 19, 2012, 01:30 PM
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
Chili,
I cannot tell what country you are from, but the deal is this:
You must use the traditional ground frequencies in the MHz ranges (27, 35, 40, 75) for whatever country you are in. Here in the USA, that would be 27 or 75mhz.
tsenecal is offline Find More Posts by tsenecal
Old Mar 19, 2012, 03:00 PM
Joined May 2007
Thank you guys. Currently I a,m in Usa so I will use 27,35,40 and 75 mhz..
But when I return to Japan I will use 27, 40 only since Futaba dont have 75 mhz made for Japan.( Japan FTC rule )
I am doing this as a gift for my friend. who has a pool.
I am also having a hard time finding 3 or 4 ch reasonable price Tx/ and Rx.
Those I saw in China etc have them but not sure they re compatible with their receivers. ( I assume it is ok to use in Usa BUT it is not ok due to their strong signal and is violation of Japan FTC rule) But it looks like I dont have much choice but bite the bullet buy the more expensive Futaba Usa Tx/Rx)
Thanks again
Old Mar 19, 2012, 03:50 PM
RC sub dude
CaptainNemo12's Avatar
Montreal, Quebec, CANADA
Joined Nov 2004
Look for online shops that carry GWS FM systems, they're an affordable alternative and are compatible with most Futaba receivers/servos.
CaptainNemo12 is offline Find More Posts by CaptainNemo12
Old Mar 19, 2012, 05:20 PM
piito's Avatar
Joined Oct 2010
What about Graupner X-412 (40Mhz version)? 6 channel FM transmitter+receiver. I have one - great thing, quality product.
piito is offline Find More Posts by piito
Old Mar 19, 2012, 05:51 PM
Joined Feb 2012
It is hit and miss, but look on ebay for a Hitec Lynx 3d. It is a 3 channel pistol grip radio that is frequency selectable. I just saw a auction for 4 receivers end at $20 bucks. With everyone switching to 2.4, older systems are selling dirt cheap.
HeliBeast is online now Find More Posts by HeliBeast
Old Mar 19, 2012, 07:36 PM
Michigan, USA
Roedj's Avatar
Joined Apr 2008
[QUOTE=chilisoling50;21080465]Thank you guys. Currently I a,m in Usa so I will use 27,35,40 and 75 mhz..
But when I return to Japan I will use 27, 40 only since Futaba dont have 75 mhz made for Japan.( Japan FTC rule )/QUOTE]
Perhaps I have misunderstood your response but just so we're on the same page here - here being the USA.
The ONLY legal frequencies for a surface craft in the USA are 27MHz, 75MHz and 2.4GHz. The 50MHz band is also available to you but ONLY if you are a licensed (by the FCC) amateur radio operator.
Experience and theory has shown us the the 2.4GHz band does not work for submarines as the signal is greatly absorbed by the water. That leaves us with 27MHz and 75MHz. My own advice would be to purchase a 75 MHz FM 4-channel radio (more channels would be even better) using PPM encoding and be done with it. I say PPM and not PCM modulation as PPM seems to work better with the various fail safes you will probably want to install to (hopefully) bring your submarine back to the surface and to the shore when all else goes horribly wrong.
I'm not sure how 75MHz would work out legally in Japan.
Good luck,
Dan
Roedj is offline Find More Posts by Roedj
Old Mar 19, 2012, 08:45 PM
Joined May 2007
Dan: No, 75mhz is not popular there and it is not approved legally in Japan. Unless hitec or Futaba goes thru the trouble get it approved. Other wise 40 and 27 are the pn;y choice left.
The only T/X approved by J is my Hitec Aurora 2.4g 9 ch which was specifically approved by them
I will check on ebay and other places recommended by you folks.
Thank you.
Old Mar 19, 2012, 11:49 PM
Philippines
Joined Jan 2005
Look for a Futaba 4GWD, it's 4 ch, 27mhz. Got mine in the US for $129.
redboat219 is online now Find More Posts by redboat219
Discussion What kind of foam is this one? whatala Foamies (Scratchbuilt) 3 Mar 15, 2012 03:49 AM
Discussion What Kind of CNC I'm Looking at? zebra100 CAD/CAM 8 Mar 06, 2012 07:07 PM
Question What kind of radio swash plate for pro piccolo? dragonal Micro Helis 4 Sep 03, 2003 04:02 AM
What kind of radio do I need for Corona 120? cmikecs Electric Heli Talk 1 Mar 28, 2003 04:46 AM
Jr Radio, but what kind of Receiver? Air 1 Parkflyers 1 Oct 04, 2002 02:55 PM
