Old Dec 04, 2009, 01:17 PM
Closed Account
Joined May 2006
Mini-HowTo
Baco-Liner Build Plans, help and advice.
Hi Guys,
After a lot of excellent work from JochenK, It is a pleasure to publish the Baco-Liner Cyclogyro build plans, and a short Noddy guide to the build sequence. I will update this post tomorrow with pics of the original.
The design has been simplified for lightness and ease of construction, it can be built with only Balsa if you prefer or have no access to Depron.
The structure could be converted to stick type, with longerons and frames/formers, what ever you want, just stick to the outline, dimensions, power requirement and the CoG position, you choose to suit your needs.
It will scale Up, but maybe not down, you are on your own with that.
all the original information is here:
http://www.rcgroups.com/forums/showthread.php?t=1125450
I will be happy to help with questions if anyone gets stuck, good luck, happy Cyclogyrating and stick up some pics if you can. Cheers,
Regards to All, Al
rotorheid is offline Find More Posts by rotorheid
Old Dec 04, 2009, 01:27 PM
RC Group therapist
Boneswamped's Avatar
DeRidder LA.
Joined Nov 2008
Yippie!!!! Thanks Al. The race is on for the first B.L. in the U.S.!!!
Boneswamped is offline Find More Posts by Boneswamped
Old Dec 04, 2009, 01:55 PM
Suck it and see
Norfolk Flyer's Avatar
Cromer, North Norfolk Coast, UK
Joined Aug 2008
Many thanks Al / Jochen.
John
Norfolk Flyer is offline Find More Posts by Norfolk Flyer
Old Dec 04, 2009, 11:06 PM
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
You're on Boneswaped dude! And the first one that loops it wins the prize!
Actually Mike, I hope you build one. I'm a little busy with other stuff.
Al, thanks for the plans...you are too kind!
Joe
jodini is offline Find More Posts by jodini
Old Dec 05, 2009, 12:41 AM
Closed Account
Joined May 2006
Build pics of ORIGINAL VERSION, go with the PLAN!
High Guys,
Anyone got her flying yet? Yes? No ?
Ok here are some pics of the Original build to help, please check you are building to the provided plan information.
Joe + Mike, and all builders, Good luck
Cheers,
Regards to all, Al
eps No Spandex in your pics please.
Old Dec 05, 2009, 06:42 PM
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Nice one Al...I can just picture Jochen puffing away on that huge cigar drawing away at his computer
For some reason I cannot open the files..must be my computer as its been playing up the last few days!!
So what kind of power plant do you reccommend for this model Al?
Spandex...LOL..that was funny pictrue!!
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Dec 05, 2009, 11:20 PM
jodini's Avatar
Joined Sep 2004
Hey Al.
Do you have the measurements of F1, F2, and F3?
Never mind! Just found them!
Old Dec 05, 2009, 11:36 PM
Closed Account
Joined May 2006
Hi Rich,
I used an OK C3536 1450kv from HK, it weighs 107g, rated at 400W, with a 40A esc+ bec, drives a 10x6 on 2 lipos or 9x6 on 3 lipos. They rate same as a Axi 2814/12 . I have a 9x3.8 APCsf running on 3 lipos.
Here's the rough drawings in pic format untill your pc is 100%,
They are INFO ONLY the .pdf files are correct.
Did you try right clicking the link 'Fuse-plan-A1.pdf' or the box with the 'X ed' out picture ? Cheers,
regards Al
Old Dec 06, 2009, 12:48 AM
Closed Account
Joined May 2006
Hi Joe,
That's the kind of questions I like, the ones where you can answer it your self,hahaha! just pulling your leg mate.
regds Al
Old Dec 07, 2009, 04:38 AM
Vertically Challenged...
Cody's Neighbour's Avatar
Ash Vale Hampshire UK
Joined Jul 2004
Great job Al and Jochen!
Thanks very much!
Bert
Cody's Neighbour is offline Find More Posts by Cody's Neighbour
Old Dec 07, 2009, 04:43 AM
Closed Account
Joined May 2006
Hi Bert,
You are very welcome mate, hope you build it,
Cheers Al.
Old Dec 08, 2009, 12:38 AM
Closed Account
Joined May 2006
Basic handling and flying technique notes.
Hi Guys,
"Forewarned is fore armed" as they say, so here is a wee heads up on what to expect in the flying and handling dept.
1. I use 40% expo for both rudder and elevator.
2. Rudder and elevator travel 30 deg a side.
3. Increasing power increases Rate of Climb.
4. Using elevator to change pitch attitude changes the speed.
5. There is a large change in rudder position for straight flight with change of power, Torque effect is noticable.
6. Make landing approach with some power to controll rate of descent.
7. Turns will tighten up into a spiral if not monitored, opposite rudder required to recover if bank gets steep. > 45deg.
8. Power off to zero reduces forward speed and increases vertical speed to a mass = drag condition (free fall) recover by applying power.
These are my reccomendations for your early 'Baco' flying, once you have it sorted you can go your own way, good luck, Cheers,
regards to all, Al
Old Dec 09, 2009, 04:03 PM
RC Group therapist
DeRidder LA.
Joined Nov 2008
Thanks for that Al,
All good information.....but how does it loop? I guess I'll let you know when I finish the build.
Regards,
-Mike
Old Dec 09, 2009, 11:57 PM
Closed Account
Joined May 2006
Hi Mike,
Good luck on the loops, if the wind drops and drys out a bit I may have a go myself later.
The recent heavy rain and flood waters have made the telephones and internet a bit iffy at the moment, and we have been maxed out at work with the extra flying to visit our neighbours in the south. Hence my tardy replies and comments to a lot of new great posts on this forum.
Cheers,
regards to all, Al
Old Dec 21, 2009, 02:55 PM
Joined Aug 2006
Toblerone source located in the United States!
Good news to all USA builders!
This vital bit of material, the Toblerone candy bar has been located at Rite Aide drugstores! Now armed with this essential component, construction has commenced on my Baco-Liner project! Yum yum!
RandyW is offline Find More Posts by RandyW
Idea Al's Cyclogyro The 'Baco-Liner' . rotorheid Auto Gyros 171 Feb 07, 2010 10:52 PM
Sold Mini super cub PNP just add your own RX! Get it while its Hot! lightspeeddud Aircraft - Electric - Airplanes (FS/W) 7 Oct 10, 2009 08:27 PM
New Product TYCO: Skyforce Charger Squadron P-51 Mustang/Police Planes...Get-em while their hot!. hoverboy Micro Ready-to-Fly 17 Jul 29, 2007 11:42 AM
For Sale 2100mah MaxAmps Cells-Get them while they last! austinelse Aircraft - Electric - Airplanes (FS/W) 46 Oct 03, 2005 05:11 PM
