Old Mar 05, 2014, 07:06 PM
brentp76 is offline
Find More Posts by brentp76
Joined Nov 2004
Help!
Bigaole 30A speed control help
I have this speed control on a HIMAXX 2812-0650 and it only seems to get to about half throttle? I dont know where the instructions are and am sure that there is some setting that needs to be adjusted? any suggestions?
brentp76 is offline Find More Posts by brentp76
Old Mar 05, 2014, 08:50 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Start with the tx on and the throttle trim at the bottom. Then move the throttle stick all the way up and plug the rx battery in. Wait for the esc to beep and do it's thing before moving the throttle back to zero. The esc should arm itself and be ready for flying. Keep in mind you should have the prop removed from the motor during this whole process in case the motor decides to spin up and cut you
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 05, 2014, 11:45 PM
brentp76 is offline
Joined Nov 2004
I have not problem arming the esc, it just wont go to full throttle.
Old Mar 06, 2014, 07:15 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
What Dr Kiwi posted is the standard procedure you should do with any ESC for the first set up, it's generally called setting the 'throttle range'.
It tells the ESC what minimum and maximum throttle setting are.
eflightray is online now Find More Posts by eflightray
Old Mar 06, 2014, 10:38 AM
brentp76 is offline
Joined Nov 2004
Ok.. so assuming I did'nt do that the first time I can do it a subsequent time and it should still work? My apologies as I have been flying giant scale gas and had everything stolen recently and have to reset
Sold Dji esc-30a opto brushless speed controller helifreak592 Aircraft - Electric - Multirotor (FS/W) 0 Jan 08, 2014 10:26 AM
Sold Dji esc-30a opto brushless speed controller helifreak592 Aircraft - Electric - Multirotor (FS/W) 0 Dec 20, 2013 04:56 PM
Sold DJI ESC-30A OPTO BRUSHLESS SPEED CONTROLLER set of 4 F450 F550 helifreak592 Aircraft - Electric - Multirotor (FS/W) 0 Dec 17, 2013 08:34 PM
Sold Dji esc-30a opto brushless speed controller quadcopter helifreak592 Aircraft - Electric - Power Systems (FS/W) 0 Nov 19, 2013 03:42 PM
Sold 30A Brushless Speed Controller TGKconnectors Aircraft - Electric - Power Systems (FS/W) 1 Oct 28, 2013 09:53 AM
